CAAD12 - dented top tube: thoughts?
bremerradkurier
by bremerradkurier
Maybe apply dry ice to the dent after the tube has been heated with a hair dryer and see if it pops out?
https://diy-auto-repair.wonderhowto.com/how-to/fix-car-dent-with-dry-ice-271175/
by 573
So I decided to ride it. I headed off up a climb, in a big gear, out of the saddle to put lots of torque through the bike. At the top, the dent seemed to have lost its 'soft' appearance and now has more of a crease to it. There are now also 'stress' lines to each side of the dent.
I descended slowly and parked it up. I think that may be it for this frame, I have no confidence in it now.
Broady
by Broady
Eeesh yeah that does look worse now, not sure I'd carry on riding that.
I would not ride it. IMO the top tube will snap the moment the front wheel falls in the first pothole.
topflightpro
by topflightpro
I think you're still OK to ride it, but keep an eye on those stress marks that are visible on the second photo.
If they start getting more defined, then it's time to hang it up.
antonioiglesius
by antonioiglesius
I still can't believe a conker did this...
OP: did you ask the shop/Cannondale to see if they can do something about it?
srshaw
by srshaw
I don't think that's safe now. I guess the forces from the head tube would push the top tube down as the front wheel hits a bump. That looks as though it will just crease further.
I doubt that would've have been covered by warranty anyway since it wasn't a defect from manufacturing but an accident that caused it.
by 573
I now need to decide what to do next, do I:
- buy the sparkly purple 2017 CAAD12 disc framset that's available at a reduced price currently (~£650 (GBP)) and swap the parts from this bike over
- buy one of the 2017 CAAD12 disc bikes that are currently available in the end-of-season sale (105 @ ~£1100 / Ultegra @ ~£1650) and swap the wheels etc over and sell the remainder of the bits of both bikes off
- stick mudguards on my Evo, fit my standard Mavic Aksiums to it and ride it through the winter and then treat myself to a new summer bike in the spring (Hi-Mod Etap probably...)
53x12
by 53x12
53x12 wrote:Guess you got yourself a new indoor trainer bike.
Bump. Take it off the road. Use it as an indoor trainer bike. Don't risk severe injury or worse by riding it on the road further.
Alexandrumarian
by Alexandrumarian
I can't remove this scary image from my mind: an evil squirrel tried to kill you with a slingshot...
Seriously now, how about repairing it with several wrapped layers of carbon cloth and epoxy? Would act as a lug taking off most stress from the sunk area.
choiboi
by choiboi
Cheaper to replace frame than teeth.
Can't believe a conker did that!
Sent from my ONEPLUS A5000 using Tapatalk
David
[b]'10 CANNONDALE CAAD10
by 573
Replacement CAAD12 disc frameset bought; the sparkly purple colourway swung it for me. Will try to avoid riding this one under conker trees...
Essentially it came down to the fact that even if this frame is OK, I just don't have confidence in it. I won't enjoy riding it as I'll always have a concern in the back of my mind that it might fail.
If anyone else wants to take a risk on the frameset (inc carbon fork etc) then drop me a message; will obviously be cheap.
darnellrm
by darnellrm
We constantly read all the fear mongering about carbon fiber bikes being so fragile, but high-end thin wall aluminum and steel tubes are even easier to damage, even though they may not crack immediately. And worse yet, they cannot be repaired ( at least not at a reasonable price ). If this were a carbon fiber frame, it could have been good as new for $200, but I would place a large wager that it would have not been damaged in the first place.
FWIW.
by 573
I have to agree, I doubt hugely that a conker would have damaged my Evo.
Both materials have different properties and both have their achilles heels. If you hydroform aluminium and shape it and stretch it out with the aim of reducing weight by making the tubes very thin in the middle where torsional strength isn't required then you obviously make that area more susceptible to impact damage.
Really though, my CAAD frame may be fine for many more thousands of miles. I'm just not happy riding it.
Superlight alu was never a great idea. I remember De Rosa Ud or Bianchi EV4 around 1000-1100gr. Nice frames but for a season or two only.
