It is currently Wed Jan 17, 2018 2:09 pm
Post new topic  Reply to topic  [ 41 posts ]  Go to page 1 2 3 Next
PostPosted: Mon Sep 11, 2017 12:26 pm
I recently bought a CAAD12 Disc as a winter bike. I bought it used, so don't have any kind of guarantee or warranty. I was riding it yesterday and had the strangest thing happen; a conker (horse chestnut) fell out of a tree and hit the top tube as I rode under.
The chances are so ridiculously slim.. how the conker didn't hit my head, or my legs and hit the toptube so accurately and how a conker can actually dent a top tube??
A quick Google shows loads of CAAD12s with dented top tubes. I guess they're pushing how thin they can make the tubes and in all of the areas it needs to be strong to cope with stress and cycling forces it is but seems to be compromised in its ability to deal with blows (albeit small ones from conkers!) at the thinnest parts of the tubes. Having seen how easily this is dented, I'd imagine clamping one in a workstand would crush it like a coke can.
So, I'm now not sure what to do with it. Should I treat this as just cosmetic, or should I be concerned that the frame could now crack or fail in a catastrophic way while riding it?
> '13 Supersix Evo Red 5.98kg
> '17 CAAD12 Disc 8.16kg
@ste_dot
PostPosted: Mon Sep 11, 2017 1:48 pm
Hmm bad luck indeed. Conkers can fall from pretty high so can be travelling fast when they land. I used to have an allocated parking space under a horse chestnut and accumulated a dozen dents in the car roof before I noticed, so yes no doubt could cause this.
I would still ride that and just keep a close eye on it for any changes / worsening
Scott CR1SL 6.25Kg | CAAD10 6.56Kg
PostPosted: Mon Sep 11, 2017 2:58 pm
Its hard to tell from the pictures, but I don't really see any creases. You might be able to pull it out with a suction cup.
PostPosted: Mon Sep 11, 2017 3:05 pm
I was just speaking to a friend about it and he said his car roof took a dent from a conker yesterday too. To hit a toptube of a bike seems to be such a freak accident though!
It isn't really creased, the dent has soft edges and the paint isn't even cracked. I'd already considered attempting to pull it out with a suction cup, like a paintless-dent-removal on a car body panel. I'll give that a try and go from there...
@ste_dot
PostPosted: Mon Sep 11, 2017 3:56 pm
Guess you got yourself a new indoor trainer bike.
PostPosted: Mon Sep 11, 2017 3:57 pm
Obviously there is a reason these alu frames are so light.
My 6532gr TIME Skylon
My 9733gr COLNAGO Master X-light
PostPosted: Mon Sep 11, 2017 6:04 pm
Unfortunate. It would be nice if you could pull that out with a suction cup as the dent will affect the strenght of the tube in compressive bending, such as when you land a 10' bunny hop over a sleeping policeman. Personally I would ride it as my experience is that unless you weigh 120kg and ride your road bike like it's a DH MTB small dents won't make a difference. Just don't sit on it though as you could make it worse.
PostPosted: Mon Sep 11, 2017 6:08 pm
yep, that's what I thought too
it sucks to have a dent on the bike, but i wouldn't trade that with my head / helmet / face / or cause a crash.
count your blessing ... and replace the frame :)
PostPosted: Mon Sep 11, 2017 8:30 pm
573 wrote:
I recently bought a CAAD12 Disc as a winter bike. Having seen how easily this is dented, I'd imagine clamping one in a workstand would crush it like a coke can.
Can't speak to the CAAD12 frame. But I clamp my toptube in my Park clamp on my CAAD7 and CAAD9 frames just fine. The dent won't have any affect.
PostPosted: Mon Sep 11, 2017 8:36 pm
You're fine to ride that as long as it isn't cracked.
Aluminum doesn't like to be dented, and it really can't be hammered or sucked back out, so the dent is going to stay there. As someone else noted, there doesn't appear to be a crease, which is a good thing.
The frame was likely weakened by the dent, but not so significantly you need to worry. Really, aluminum will form a crack and tear, but it's not catastrophic. So, go ahead and ride the heck out of it until you see it crack.
Lastly, yes, the aluminum is very thin, and has been getting thinner as they strive for lighter frames. Still, it was possible to dent and break heavier aluminum frames. I lost an 03 S-Works E-5 to a dent. I went down in a crash, and my bar slammed into the top tube. The frame survived about six more weeks of racing before it cracked. I'd still put it on a trainer though if I needed to.
PostPosted: Mon Sep 11, 2017 9:26 pm
I would imagine the tube is so thin there because there is little stress in that area. I would ride it if it were mine, but keep an eye on it. Any sign of cracking or getting worse then there is an issue.
PostPosted: Mon Sep 11, 2017 11:14 pm
I have a similar dent in my CAAD5 top tube. My paint is not single color in the dent area, so it's harder to see. It's been there for years with no changes or negative effects. For the most part, I have forgotten that it's even there.
"You can't get there from here"
PostPosted: Tue Sep 12, 2017 2:33 pm
Should be fine for a long time
Sent from my SM-G935W8 using Tapatalk
PostPosted: Tue Sep 12, 2017 2:35 pm
I'd ride this without concern.
PostPosted: Wed Sep 13, 2017 2:49 pm
Also, if it's any comfort my CAAD5 as well as my 1987 Cannondale Crit Racing Frame have an "engineered dent" in the drive side chainstay for chain/chainring clearance. I suspect your CAAD12 has one also...
There are no new unread posts for this topic. Caad12 help
raffit78
Thu Jun 01, 2017 3:00 am
are View the latest post
There are no new unread posts for this topic. Supersix Evo vs CAAD12
Thenuge
25
5146
Sat Oct 07, 2017 11:54 am
Peperami View the latest post
There are no new unread posts for this topic. CAAD12 headset
tomee
Fri Feb 03, 2017 1:58 am
tomee View the latest post
There are no new unread posts for this topic. CAAD12 for climbing?
superdx
33
7211
Sat Mar 11, 2017 1:59 am
MisterMuncher View the latest post
There are no new unread posts for this topic. caad12, bb30a + hollowgram si
are
Thu Apr 13, 2017 2:18 pm
evan326 View the latest post
Users browsing this forum: crux, KCookie, MagicShite, MayhemSWE, ride1970, zirxo and 39 guests
cron
