It is currently Sat Jan 20, 2018 4:07 pm
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Fri Sep 08, 2017 2:45 am
I'm trying to come out with a junior gear cassette for steep climbs, 14-30 setup.
Besides Spécialités TA (custom setup) maybe I can combine Shimano 9100 bigger cogsets with the 6 first junior gearings 6800 cogs ? Either way it would be an expensive combination...
Louis :)
PostPosted: Fri Sep 08, 2017 4:12 am
Short cage shimano rd can handle a 32, so that might be a cheaper experiment with two different 6800 cassettes.
PostPosted: Fri Sep 08, 2017 11:21 am
Yeah ... :oops: the WW in me got excited about the possibiliy of building a cassette lighter than 300g + :x .
I'm on SRAM so would have to use a Wifli rd I guess.
Louis :)
PostPosted: Fri Sep 08, 2017 11:46 am
11-12-13-14-15-17-[19-21-24]-[27-30] = CS-R9100
14-15-16-17-18-19-[20-21]-[23-25-28] = CS-6800
"with 6 juniors cogs" you will get two 19:
14-15-16-17-18-19-[19-21-24]-[27-30]
You can try [21-23-25] from 11-25T/12-25T/11-34T:
14-15-16-17-18-19-[21-23-25]-[27-30]
PostPosted: Fri Sep 08, 2017 11:22 pm
OK, great explanation, thanks :beerchug: !!
I'll definitely take a look at it.
Louis :)
PostPosted: Fri Sep 08, 2017 11:31 pm
If you do that much climbing you will be descending a lot. You will need the 11, 12, and 13. Just get the 11-30 and be done with it.
I bought a 11-34. Before my first ride I swapped the 11 cog with a 12 cog, thinking that I will need the 12 cog more than the 11. I was dead wrong. I use the 11 more than I realize! I put the 11 back and I didn't miss the 12.
I only use the 11-34 for special climbing rides.
PostPosted: Sat Sep 09, 2017 7:45 am
I take 14 to 19 of a 6800, plus a 20 loose (Y1PJ20100) of a 5800, 21-24-27 (Y1RK98020) of a Xt Cs-M8000 and Miche Primato Light 30 last position
PostPosted: Sat Sep 09, 2017 9:03 pm
Thanks ritxis !!
What's the Weight of that 'frankencassette" :) ?
I guess you need a Miche spacer between the 27 and the 30 cog ? How many km:s on the cassette, and how is the alloy cog doing in terms of shifting quality and durability ?
Louis :)
PostPosted: Mon Sep 11, 2017 2:51 pm
LouisN wrote:
Thanks ritxis !!
Louis :)
Do not check the weight, nor do I remember the size of the spacer, i'll check
Shifting, i´its goog As is normal, with a complete cassette will be somewhat finer, but I'm happy), durability? I think it will be satisfactory...Ultegra/Xt cogs......with 30 Miche (this last one will be used, but not as much as the rest)
greeting for San Sebastian (Basque country, Spain)
There are no new unread posts for this topic. Anyone tried 9100 brakes on etap?
Nejmann
Sat May 06, 2017 7:43 pm
Daniel1975 View the latest post
There are no new unread posts for this topic. Madone 9 mechanical 9100
popandmod
Thu Dec 28, 2017 8:24 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Anyone tried weight tuning on Shimano 9100 yet?
Sybarite
Wed Aug 02, 2017 2:55 pm
Sybarite View the latest post
There are no new unread posts for this topic. 9000 left arm on 9100 crankset??
Delorre
10
987
Wed Nov 01, 2017 3:26 pm
Philbar72 View the latest post
There are no new unread posts for this topic. Shimano DA 9000 vs 9100 crankset
Grimpeur
28
2671
Fri Jan 05, 2018 12:29 pm
BdaGhisallo View the latest post
Users browsing this forum: Alex60, cwdzoot, dukeduke1, duzza, fitty4, Miller, woodnat1, Yahoo [Bot], Zakalwe and 39 guests
cron
