It is currently Mon Dec 18, 2017 4:42 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Thu Aug 24, 2017 11:12 pm
This is interesting, unless anyone more technically minded than me can find a flaw with the methodology.
Most of the big players were subject to testing and only a handful are actually within the manufacturers stated accuracy. Luckily my Quark comes out ok (in the middle of the best performers), Stages have a proper rinsing though.
https://roadcyclinguk.com/how-to/fitnes ... think.html
PostPosted: Thu Aug 24, 2017 11:44 pm
It's interesting. Like the article, I wouldn't be worried too much about the the accuracy in regards to "true" power output unless you are, for some reason, comparing the output between multiple separate units. Otherwise, the results are normalized to your unit and bike (a "300w" to you will mean something slightly different to someone else, but that would always be the case given that everyone has different fitness levels). Having multiple bikes equipped with PMs would be a concern though when riding to power. Only way to be for-sure is to treat the numbers separately (ie. measure each effort based off of separate FTP on both bikes/PMs).
The most alarming thing in the article is the variation with the exact same unit. Stages loses out here again, but the article admits (and shows) that many were precise while a few weren't. They tested 12 SRM, 10 PowerTap, 11 Quarq, 13 Stages, 3 Verve, 2 Power2Max, 1 Garmin, 1 Polar, 1 Rotar. Was the testing sample large enough to conclude that this behavior is systemic or they just had a few defective ones (4 out of 13 of the Stages had over 2% variance in the individual precision test)?
BMC Teammachine SLR01 (2018) | Rodriguez Rainier (2015)
PostPosted: Thu Aug 24, 2017 11:45 pm
It seems it's the same study that was discussed here viewtopic.php?f=3&t=54198&start=3120#p1315887
PostPosted: Fri Aug 25, 2017 4:00 am
It's a pretty shitty "study" that lumps multiple versions of branded PMs as one. The sample sizes are also way too small, especially for any brands outside the top 4.
PostPosted: Fri Aug 25, 2017 3:44 pm
Who cares about 4%
PostPosted: Sat Aug 26, 2017 10:49 am
fasdflkjweorinjs wrote:
Who cares about 4%
So long as it is always either 4% or -4% that's fine, but if the precision is off and it can vary from -4 to +4 from ride to ride, a 350w interval can go from being 334w to over 366w. That's a 32watt spread. Not at all insignificant.
PostPosted: Sat Aug 26, 2017 12:39 pm
Which you'll be doing when you get a new powermeter.
Accuracy matters because when you get that new powermeter, if it's different than your previous one than you're essentially starting over with all your power data. Which is hors categorie suckitude.
A big reason I won't touch a one-sided powermeter with a stick.
Cat 1
There are no new unread posts for this topic. First Power meter suggestions
[ Go to page: 13 4 5 6 7 ]
merser
91
7642
Wed Aug 02, 2017 5:38 pm
evan326 View the latest post
There are no new unread posts for this topic. Power meter lifespan
stormur
7
989
Sun Aug 20, 2017 2:55 pm
RyanH View the latest post
There are no new unread posts for this topic. power2max power meter
bikeracer99
35
3436
Thu Mar 30, 2017 6:12 am
PinaF8 View the latest post
There are no new unread posts for this topic. Power Meter For Campagnolo
[ Go to page: 1 2 3 4 ]
lw11
46
5426
Sun Jul 23, 2017 11:34 pm
Mockenrue View the latest post
There are no new unread posts for this topic. power meter Q again, compatibility
Boshk
Mon Jul 24, 2017 5:31 pm
pdlpsher1 View the latest post
Users browsing this forum: Bing [Bot], bomber, Catagory6, Hapsmo911, nick312, slowK and 30 guests
