It is currently Sat Dec 16, 2017 10:15 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Thu Aug 24, 2017 11:33 am
I managed to get a large blob superglue on my Supersix seat tube after rolling off too quickly when using it to repair a tyre, does anyone have any recommendations on what I should use to remove it?
It's the Black Inc matte carbon finish with a very thin layer of clearcoat so nervous about using a razorblade and would rather go with chemical.
PostPosted: Thu Aug 24, 2017 12:11 pm
Acetone should remove the superglue. If you struggle to find any, it's used in lots of nail-varnish removers.
> '13 Supersix Evo Red 5.98kg
> '17 CAAD12 Disc 8.16kg
@ste_dot
PostPosted: Thu Aug 24, 2017 12:47 pm
Acetone first option. But first try it somewhere on the frame where it is not visible to make sure it is not damaging the clearcoat. Problem is these days most nail polish removers are very low in acetone and might be useless. On the other hand getting pure acetone can be difficult. In any case do not try other solvents (such as paint or lacquer thinner) because you can easily melt the lacquer. The razor technique works, but only if you have experience, and it is especially hard on a round surface. You need to use thin tape around the superglue, or the outer thirds of the razor blade, then scrape as much as you can. Then use progressively finer sandpapers to blend everything in then finally buff.
PostPosted: Thu Aug 24, 2017 1:11 pm
How about the stiff plastic like a credit card for scrapping? Some Goo Gone soaked awhile and then the card .. how I handle tough old decals. Couple experiences w super glue here makes me think it's vulnerable vs Goo Gone or similar agents.
PostPosted: Thu Aug 24, 2017 1:47 pm
Thanks all, I'll try Goo Gone as got some already then will raid the better half's makeup drawer if that doesn't work! I'll report back on what works for anyone interested in the future.
PostPosted: Thu Aug 24, 2017 3:11 pm
normal warm soapy water should move it eventially,
and no i didnt find out because i accidently glued my hand to a desk... no honest!
PostPosted: Fri Aug 25, 2017 10:38 am
If all else fails get some of this stuff: http://uk.rs-online.com/web/p/adhesive-activators-primers-debonders/0473405/
Thats the proper way to do it
There are no new unread posts for this topic. Removing Graphic From Hed Belgiums
Mr.Gib
Sun Mar 05, 2017 9:57 am
stormur View the latest post
There are no new unread posts for this topic. removing logo from chain ring
Timujin
Fri Mar 10, 2017 8:23 am
marynoland View the latest post
There are no new unread posts for this topic. Removing logos from a veloce crank
TomColnago
Sat Jan 14, 2017 12:25 am
TomColnago View the latest post
There are no new unread posts for this topic. removing printed logos from wheels??
sneeeky
Mon Oct 16, 2017 3:17 am
maxxevv View the latest post
There are no new unread posts for this topic. Alternative Tool For Removing Battery Cover
ipenguinking
7
396
Sat Oct 14, 2017 3:20 pm
ipenguinking View the latest post
Users browsing this forum: erik$, euan, Jimbo1983 and 30 guests
