It is currently Sun Oct 22, 2017 1:28 pm
 Post subject: Rim tape check
PostPosted: Wed Aug 23, 2017 5:16 pm
Hello,
Just a quick question on rim tape fit. My rims are the wide kind with 19mm inner diameter. I got this 16mm Velox tape on but I am not sure if it may be a bit small. Should I go 19mm? or would that be too wide and make it difficult for cotton beads to sit properly? It is covering the whole gutter and all the spoke holes (which are thankfully not offset) but I wonder if there is a risk the tape may lift or slide and allow the latex tube to access the spoke holes.
Image attached.
Thanks in advance.
 Post subject: Re: Rim tape check
PostPosted: Wed Aug 23, 2017 5:18 pm
if it sufficiently covers all the spoke holes you should be fine.
The New: BH http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=117760
PostPosted: Wed Aug 23, 2017 6:12 pm
Hi there. There would be about 2mm of tape beyond each side of the hole. Enough? I fear for trying to get a wider one in case it raises the bead enough for it not to sit properly.
PostPosted: Wed Aug 23, 2017 6:18 pm
the tire bead should fit regardless of the tape...since it goes up and into the lip of the rim when inflated.
on a few wheels, i use the veloplugs, which weigh less overall and only covers the holes so the tube doesn't blow through them.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Wed Aug 23, 2017 8:29 pm
I run 2 wraps of tubeless type tape, makes fitting tires much easier.
PostPosted: Thu Aug 24, 2017 7:22 am
+1. I also use Veloplugs if the spoke hole is the correct diameter and shape for Veloplugs. Veloplugs is the best and lightest solution. Tubeless tape is good too but at twice the weight of Veloplugs. Some rims have a curved inner rim shape and Veloplugs won't work.
PostPosted: Thu Aug 24, 2017 7:27 am
1 run of 19mm blue Schwalbe tubeless rim tape is only 6 gr, so not a lot more than veloplugs. Ok, maybe the double of weight, but that's still only 3 gr :mrgreen: But you are right, veloplugs is a lot lighter than 90% of the rimstapes found on stock wheels. Roval rim tape was almost 25gr per wheel :shock:
Canyon Ultimate CF SLX 2013
Scott Addict Orica Greenedge
Canyon Endurace CF SLX
PostPosted: Thu Aug 24, 2017 11:56 am
I'm actually only using 1 run, but seeing the tape deform into the nipple holes I'll use 2 in the future on non-weenie wheels ;)
There are no new unread posts for this topic. Tape instead of hoods?
whydobearsxplod
13
1169
Fri Sep 29, 2017 4:46 pm
whydobearsxplod View the latest post
There are no new unread posts for this topic. TechFlex as bar tape experiment
WannabeWeenie
Thu Jan 12, 2017 2:36 am
WannabeWeenie View the latest post
There are no new unread posts for this topic. Favorite bar tape for aerobars
Kurets
Sat Jul 08, 2017 11:34 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Suggestions for finishing bar tape ?
wobbly
22
1615
Sat Jul 15, 2017 6:11 am
Nefarious86 View the latest post
There are no new unread posts for this topic. Attachment(s) Silva chrome bar tape
ksy8828
Tue May 09, 2017 2:51 pm
Stolichnaya View the latest post
Users browsing this forum: alorast, Baidu [Spider], Erwin, Google [Bot], jlok, jobvisser, simplemind, uraz and 27 guests
