It is currently Tue Oct 17, 2017 1:14 am
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Mon Aug 21, 2017 12:05 pm
Hi,
I've just purchased a used CX bike for the winter. The Sora 9 speed is lightly used but the chainset is too big for me. My friend has a 105 5800 11 speed knocking around I can have for mates rates - will it work with the 9 speed chain?
Maybe silly question?!
Thanks
Matt
PostPosted: Mon Aug 21, 2017 3:02 pm
Yes it works, using a 10 speed chain would help.
PostPosted: Mon Aug 21, 2017 3:26 pm
9, 10 and 11-speed chains all have the same internal width. It's the thickness of plates and pin length that changes. Maybe 8-speed as well but I don't have one around to measure, but I do know that a 9-speed chain works very well with 7-8 speed sprockets and cranks.
So, yes it will work.
And I'd agree that when it comes time for a new chain a 10-speed will probably shift better.
There's sometimes a buggy.
One.
PostPosted: Mon Aug 21, 2017 3:40 pm
Thanks guys, it's having a new chain as part of me servicing it and cleaning - 10 speed it is that's great thanks all!
PostPosted: Mon Aug 21, 2017 5:45 pm
You should be using an 11 speed chain with an 11 speed chainset. The external width also matters when it comes to chain rub and pick up pins. But then you run into the issue that the FD may or may not play nice with the new narrower chain, especially if you have the new long arm FDs which may be at their adjustment limits even if the stock equipment.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
PostPosted: Mon Aug 21, 2017 6:03 pm
Nope......
PostPosted: Mon Aug 21, 2017 6:19 pm
2lo8 is right and goodboyr is right. Sometimes using an 9 speed chain on an 11 speed chainset can cause issues (minor ones in general). Using an 11 speed chain my cause some rear shifting issues and front shifting issues as well.
The best compromise is a 10 speed chain that way you should encounter no issues.
www.thecycleclinic.co.uk
PostPosted: Thu Aug 24, 2017 7:21 am
goodboyr wrote:
Nope......
Yes.
I play around with lots of unorthodox combinations. Mismatched parts may work fine, but certain kinds of combinations tend to be more problematic than others. Chainsets usually work best when paired with the chains and FDs they're designed for. Chainring spacing, ramps and pins are designed for certain chains. Cassettes are much more tolerant of a chain being too narrow because the external dimensions really don't matter since there aren't pick up pins. The tooth shaping and ramps on cassettes have more to do with the internal dimensions of the chain, giving room for the chain to flex or to catch the inside of a plate. The RD also moves the chain using the internal part of the chain.
PostPosted: Thu Aug 24, 2017 10:26 pm
I'm definitely not clear on what you are saying. Please explain how ramps and pins can be specific, when every chain has exactly the same pitch....even better, show some examples of what you mean.
PostPosted: Fri Aug 25, 2017 2:01 am
I don't think anyone has demonstrated any difference in spacing between 10 and 11-speed cranksets. I've found them totally interchangeable.
One.
PostPosted: Fri Aug 25, 2017 2:54 am
Spacing isn't the only thing that matters. Chainring spacing can be increased if there's a ramp/bridge to guide the chain down to the small ring without skating. Using a wider chain than specified usually means chain rub in the form of the pins trying to pick up or rubbing the chain in cross chain combinations. Some pins are engineered not to just have the chain rest on them, but hook an outer plate. Generally they are engineered to minimize chain rub, but maximize chain retention. It's a balancing act which is why they work best with the chains they were designed for. I believe that chain flexibility plays some role in the designing of shift features as well. It's not that they're entirely incompatible, which I never said, but there are sometimes issues. Usually you can run then +/-1 chain speed in the front with minor or no issues, and at least +2/-0 in the back with no issues. My opinion is if you want no problems, you should run the front as close to designed as possible (and I don't on multiple bikes for various reasons, and shifting suffers for it). Too narrow a chain rarely presents a problem in the rear.
PostPosted: Fri Aug 25, 2017 1:14 pm
Where are you getting this info from about pin and chain Ring design?
Sent from my SM-G900W8 using Tapatalk
My RCA
PostPosted: Fri Aug 25, 2017 1:28 pm
I think 2lo8 has a point. The experiment is quite low risk though so try a 10speed chain and if you notice anything weird then try 11s.
I mean running a different chain than the chainset was designed for could have some consequences.
No need to get pissed off. :D
/a
PostPosted: Fri Aug 25, 2017 2:31 pm
/a
Huh? I truly want to understand where the reference info is coming from. Definitely not pissed off.....
There are no new unread posts for this topic. Campagnolo 11 speed crank w/ 9 speed chain Compatability
rgamble
Fri Oct 28, 2016 9:09 am
icenutter View the latest post
There are no new unread posts for this topic. Family Budget 5700 10 Speed to 11 Speed questions
Afnole16
15
1082
Thu Dec 22, 2016 5:06 pm
JamesGRC View the latest post
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sun Apr 16, 2017 1:10 am
BRM View the latest post
There are no new unread posts for this topic. Mixing 10 speed sram and 11 speed 105
jowen
Mon Mar 06, 2017 8:40 am
kulivontot View the latest post
There are no new unread posts for this topic. Record 11 Speed Rear Der - Cable Angle Question
alistaird
Fri Dec 30, 2016 11:59 pm
5 8 5 View the latest post
Users browsing this forum: aplcr0331, DiegoMendes, Google Adsense [Bot], Lookryder, morganb, Seedster and 35 guests
