It is currently Tue Oct 17, 2017 5:11 am
Post new topic  Reply to topic  [ 72 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Tue Aug 15, 2017 6:13 pm
markgoldstein wrote:
I've been an enthusiastic follower of the N+1 rule for the last few years, but I'm now thinking of reducing my fleet, and maybe even trying to run just one bike all year round.
My all-time favourite bike is the Cannondale Supersix Evo HM - I've currently got a 2015 model with SRAM Red 22.
Here's my list of requirements for the ideal single bike option:
- on-road only (no gravel requirements)
- suitable for everything from fast 3 hour club-runs to more sedate 300km audaxes
- 25mm tyres in summer, 28mm tyres with full mudguards in winter (Raceblades don't really cut it for group riding)
- "relatively" lightweight (hopefully sub-7kg)
- aggressive endurance geometry, rather than full-on race (my Supersix is a 54cm frame with the 25mm headset cap fitted)
- ideally SRAM Etap groupset, if buying a stock bike
- disc brakes
Possible candidates so far are the new Cannondale Synapse, which in terms of fit has a very similar stack/reach to my Supersix if it's possible to use a 10mm headset cap.
And...ermmm...any other suggestions?
Thanks!
You could consider a Canyon Ultimate / Endurace CF Slx Disc. Plenty of clearance for fenders, even with 28mm conti 4000s. No eyelets present on the frame though. Mine is sub 7kg without any crazy part, and still with the older, heavy 785 shifters.
Canyon Ultimate CF SLX 2013
Scott Addict Orica Greenedge
Canyon Endurace CF SLX
PostPosted: Tue Aug 15, 2017 7:49 pm
I'd prefer a frame with "proper" mudguards, as I do a lot of group rides throughout the wet and muddy UK winter. I've tried Raceblades and Crudguards before, and they're ok if you're not riding with anyone else, but not great for those behind.
PostPosted: Tue Aug 15, 2017 8:01 pm
What was the one bike that you had?
Trek Domane.
It ticks all your boxes. The only area where it falls short for me is the forks and slight lack of front end sharpness in crits. That trait is part of what makes it a nice bike to ride 1+hr, so dont think I am writing it off.
Most of the new bikes that fall into the one-bike category dont appear to be all that compliant in the front. It could be an issue with an aggressive fit and long time in the saddle.
PostPosted: Tue Aug 15, 2017 8:18 pm
Anyone ridden the Focus Paralane?
https://www.evanscycles.com/focus-paral ... e-EV308651
PostPosted: Tue Aug 15, 2017 10:30 pm
One bike to rule them all. The holy grail of bikes. I've been looking for it as well for quite some years now. Haven't found it yet though ;-)
First of all, if you want to be able to have both 28 mm and fenders, you're not gonna find it among the pure performance race bikes with aggressive geometry. That means that it wont be a light frame either. Probably not even a carbon bike, if you're looking for fender eyelets on the frame. Ticking all your boxes wont be possible IMO.
But take a look at the Kinesis Racelight 4S disc. It ticks all your boxes except light weight. It takes 28 mm tires and fenders, has fender eyelets both front and rear. Both rim brake and disc brake is possible. Aggressive geometry. On road only. And doesn't break the bank.
PostPosted: Thu Aug 17, 2017 7:54 am
What mudguards are you using with your Endurance, if any?
PostPosted: Thu Aug 17, 2017 8:15 am
I have CRUD MK3's, but only used twice last winter.
PostPosted: Thu Aug 17, 2017 8:30 am
Left field...and not out yet...Bowman Pilgrim X?
https://bowman-cycles.com/product/pilgrims-project-x/
PostPosted: Thu Aug 17, 2017 8:50 am
http://www.wearespooky.com/dune/
Using Tapatalk
PostPosted: Thu Aug 17, 2017 9:12 am
I went this road .... 5y ago. Then came back to road-cx idea and now again 1bikeonly.
Perfect solution ? Rather not. But compromises are very few, and I can easy live with them.
My choice was BMC CX01/ Sram Red / handbuilt DT Swiss wheels / Quarq dZero / Fizik saddle / Easton cockpit. For road have Look Keo Blade Ti pedals, for commuting & other kind of roads Look Quartz Ti.
Road setup weights 7.5kg, anyroad 200-250g more. Frame size "57" so 56cm TT. NOT XS as many "light" bikes here ;)
Never been more happy.
Can I go down with weight ? Sure :) Tubulars, saddle, cockpit and PM can save 500-700g easy, so can be at 6.8 / 7kg road/cx respectively.
Current setup can survive everything #reasonable , and many not so much as well. Under 182/85kg rider.
Mark Twain
PostPosted: Thu Aug 17, 2017 2:55 pm
Having just discovered these...
http://rawmudflap.uk/about-mudflaps/
I'm now more open to the idea of crossing off "full mudguards in winter" from my requirements list.
PostPosted: Thu Aug 17, 2017 3:11 pm
Custom Ti would be my vote. I was going to have Eriksen do a disc build with clearance for 32mm tires. My Litespeed is still my favorite bike that I have owned.
I did give up on that idea though because I wanted to use mine for light off road duty too but quickly learned that I'd need a new pedal since speedplays are rubbish in dirt. I also found that I didn't like the ride of 32mm tires on the road. They need to be pumped up quite a bit to not feel squishy in corners and out of the saddle. At that point, they tend to be less comfortable than a good 25mm tubular.
Strava
Current Stable. The Snob Machine | The Crumpton
The Ex's. LS Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | LS Xicon: 5.76kg | C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg | Evo - 5.18kg | LS Classic - 6.7kg
PostPosted: Thu Aug 17, 2017 4:40 pm
baum orbis :mrgreen:
PostPosted: Thu Aug 17, 2017 4:46 pm
I have a pair of those. Decent flaps and not expensive. But as others have mentioned, I'd recommend buddy flaps. They will not wear or break in at least the next couple of winters.
PostPosted: Thu Aug 17, 2017 8:30 pm
How are those different to the Raw one? (which have the advantage for me of being made in the UK, rather than the US)
There are no new unread posts for this topic. Calipers rule and discs shouldn't win
dynaserve
7
863
Tue Jun 27, 2017 2:58 pm
mattr View the latest post
There are no new unread posts for this topic. Aiming to participate in next L'etape, need clarification on interpreting equipment rule
ninjasloth
27
1952
Sat Apr 15, 2017 12:53 am
964Cup View the latest post
There are no new unread posts for this topic. What shoes to replace shimanos 131s
kelih
Thu Jun 29, 2017 2:18 pm
kelih View the latest post
There are no new unread posts for this topic. Which Model of Helmet Do You Wear and Why? How Frequently Do You Replace It?
[ Go to page: 1 2 3 4 5 6 ]
Squashednuts
80
6208
Tue Sep 12, 2017 3:27 pm
MXGimp View the latest post
There are no new unread posts for this topic. How to decide what to replace in a bent rear derailleur
nemeseri
Mon Aug 07, 2017 9:04 am
MayhemSWE View the latest post
Users browsing this forum: beanbiken, Bing [Bot], Calvaroz, kurisu, MomentumR5, nick312, Yahoo [Bot] and 43 guests
