It is currently Mon Dec 18, 2017 3:53 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Sun Aug 13, 2017 3:56 am
Anyone using these? A few on eBay for 9000s, appreciate any insights past or present.
PostPosted: Mon Aug 14, 2017 12:47 am
Not a good material for spindles.
PostPosted: Mon Aug 14, 2017 2:37 am
Look keo blades seem to have no issues with Ti spindles -- at least I can't find many complaints about them..
Appreciate the response, curious what your background is with them...
PostPosted: Mon Aug 14, 2017 2:43 am
I've been curious of this too. I've seen them online but not heard much of them.
Doesn't speedplay offer a factory pedal with Ti spindles? What do you know that they don't?
My Strava Profile
2016 Cannondale CAAD12
PostPosted: Mon Aug 14, 2017 3:42 am
I have thousands of Km's on my very well used(before me) Keo Blade Ti's. Zero issues
20% cyclist/80% J.I.T
PostPosted: Mon Aug 14, 2017 4:03 am
Similar as others - I have great vibes with Campagnolo Ti spindles pedals. While not answering the question about shimano pedals I just needed to join the others being vocal that Ti spindles are very worthy on pedals.
PostPosted: Mon Aug 14, 2017 9:24 am
The difference is in the bearings.
Shimano DA pedals use the spindle as part of the bearing race. Ti isn't a great material for bearing races.
Look pedals use cartridge bearings, which run off their own races and are in turn mounted onto their Ti spindles.
PostPosted: Mon Aug 14, 2017 10:40 am
Works great for XTR:
PostPosted: Mon Aug 14, 2017 1:05 pm
So not a great material for this particular spindle design, not necessarily for pedal spindles in general.
I have a pair of 35$ Ti spindles on my Speedplay Zeros, they have been ridden plenty hard and crashed a couple of times and are holding up just fine.
PostPosted: Mon Aug 14, 2017 8:57 pm
Very enlightening comments. Thanks to all.
PostPosted: Mon Aug 14, 2017 9:29 pm
I havent got any personal experience, but when i googled the same question a year ago, the general agreement was, that these chinese titanium spindles for shimano doesn't last and are flexy for those who are not super thin.
PostPosted: Tue Aug 15, 2017 12:32 pm
Has anyone ever tried to make a titanium spindle with a press-fit steel bearing race? That would allow weight savings without the durability penalty, just a higher cost.
PostPosted: Tue Aug 15, 2017 12:44 pm
^ to do that, the section would have to be turned down to a smaller diameter - might introduce unwanted flex, or produce a stress riser in the spindle. Ti is not so forgiving of stress risers.
PostPosted: Tue Aug 15, 2017 1:03 pm
Yes, it would need to be turned down smaller, but not much. If the steel collar can be fully supported it could be made quite thin. Proper heat treating would be key so that it's not too brittle and breaks but hard enough to withstand the bearing loads. It still could be problematic but without knowing the dimensions it's hard to say. Ti tolerates threads and it's tough to produce a worse stress riser than threads :) I don't see that being the issue that makes this not work.
PostPosted: Sun Aug 20, 2017 6:49 pm
I had Ward Ti spindles on my Shimano PD-A600 road SPDs and I got 3,500 miles on them. The play was extreme by this point and they spindles worn just as seen above.
I'm 60kg, and this was purely road use.
So, sadly, back to the steel Shimano ones.
Not felt inclined to try the Chinese shyte that's widely available as they can and will only be worse at best, and unsafe at worst.
There are no new unread posts for this topic. Titanium Spindles
Corsair05
Wed May 24, 2017 5:02 am
glam2deaf View the latest post
There are no new unread posts for this topic. Attachment(s) Chinese Speedplay replacement titanium spindles
Shrike
29
4058
Tue Nov 21, 2017 7:02 am
SampsC50 View the latest post
There are no new unread posts for this topic. Powertap P1 Pedals
mattCSUK
Fri Feb 24, 2017 5:41 pm
Butcher View the latest post
There are no new unread posts for this topic. pedals advice?
Musiker
Sat Sep 16, 2017 7:19 pm
Musiker View the latest post
There are no new unread posts for this topic. Look Keo pedals - regrease frequency?
mvcap
Sun Oct 22, 2017 5:04 pm
mvcap View the latest post
Users browsing this forum: Baidu [Spider], CP, hamd, sabba and 53 guests
