Bleed screws in Shimano hydraulic levers
lovemyway
by lovemyway
Hello,
Does anyone know if the bleed screw used in the "old" hydraulic levers - Shimano code Y8V398010, is compatible with the new R9120/R9170 levers? The guys at my LBS have stripped the head and I need the replacement parts.. Both the R9120 and R9170 pdfs state the the part number for the screw is Y0C698030 - http://si.shimano.com/pdfs/ev/EV-ST-R9170-4079.pdf.
I've scrolled through the R9150 dealer's manual, but couldn't find any details about this specific screw.. They do look very similar to me, though. I'm literally screwed.
Any ideas? Should I try to machine the screw myself?
Marcin
"old" screw, Shimano code Y8V398010
Screw from the R9120/R9170 diagrams, Shimano code Y0C698030
ooo
by ooo
old screw = same thread as funnel
new screw = same thread as funnel adapter
compare funnel adapter external thread (or screwed screw thread) vs funnel thread
funnel adapter
lovemyway
by lovemyway
Meh, how do I get the required part?
ms6073
by ms6073
lovemyway wrote:The guys at my LBS have stripped the head and I need the replacement parts.
Help me to better understand exactly how the shops negligence has became your problem? If the LBS cannot source a part to replace the bleed screw, then they need to source a replacement shifter!
lovemyway
by lovemyway
//EDIT: I got the message from my LBS that Shimano guy will try to send the screws tomorrow and he'll take them off the new levers if needed..
Well, I'm just trying to speed things up. The guy that is responsible was asked to call the Shimano, he said he prefers to email them. So I'm waiting for 2 guys to figure out where the screws are and it might take some time (especially now that I see how my LBS handles these things).
I was chatting with bike-components.de myself and got the information they can order the part for me, but it will take few weeks
Info@bike-components.de wrote:We can order this article especially for you. So an exchange is not possible.
Item: Bleed Screw & O-Ring
PL-Item-Nb.: Y0C698030
Price: 5,70€ incl. 19% VAT
Availability: 4 weeks
Just one question, though, If I get the old screw and try to screw it the opposite direction, won't it work?
guxo
by guxo
Same problem
guxo
by guxo
have you tried with plastic dummy bolt which comes in the conecting port of the lever?
seems to be the same thread. No need too much torque so so plastic may do the job
Just a question: how have you removed the damaged bolt?
guxo
by guxo
guxo wrote:I have the same problem.
These are the plastic bolts I'm talking about. The thread seems to be the same that the funnel one.
My problem is how to remove de worn ones.
PaulH
by PaulH
I tapped a torx screw head into the soft plastic and was able to undo the old bleed screw
guxo
by guxo
thank you
I 'll try
PaulH
by PaulH
Let me know if you need a photo and I’ll take one tomorrow
guxo
by guxo
A picture will help, yes. Thank you.
Tapping this shifter scares me ...
guxo
by guxo
PaulH
by PaulH
guxo wrote:A picture will help, yes. Thank you.
T10 size
guxo
by guxo
thank you again
Could you re-use the screw?
