Canyon aeroad steerer plug adjustment
by dannyBBo
I hv loosed the headset expander, but i can't tighten the headset expander again.
How can i fix it? Thanks!
by alcatraz
If it's very loose then you probably have to take it out and reset it to be a bit grabby before inserting it again.
If it's just barely holding then try to either tighten it really quick to get it started or put a small mini screwdriver in the little gap to try and hold it enough to start grabbing the tube.
