It is currently Thu Jan 18, 2018 5:10 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Sun Jul 30, 2017 10:47 pm
Good evening,
I want / need to switch chainrings on my Red crankset but was wondering how I can remove that second bolt (opposite to the one behind the crank)? The chainring came with a tiny rubber or plastic plug that probably goes in there once it has been removed.. but what's the 'correct' way of removing it? Punch it out with a puncher.. or pull it out somehow..?
Cheers and thanks,
.J
PostPosted: Mon Jul 31, 2017 7:11 am
Drill it out. I forgot the bit size.
You also need a special hidden nut which isn't included with the new chainring. You could reuse the old one by pressing the old one out of the chainring.
PostPosted: Mon Jul 31, 2017 7:43 am
Take pliers and yank them out (really, it even says so somewhere in the docs iirc). You can put one of the old bolts into the old hidden nut and knock it out with a hammer. Will pull itself in on tightening the screw on the new ring.
PostPosted: Mon Jul 31, 2017 8:05 am
I used a locking vicegrip, voila!
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
PostPosted: Tue Aug 01, 2017 10:43 pm
Pliers and yanking the bolt out worked perfectly fine.. thanks everyone!
There are no new unread posts for this topic. Campagnolo chaingrings
Shmitt
Wed May 31, 2017 2:23 am
BRM View the latest post
There are no new unread posts for this topic. Attachment(s) Question about sram hidden bolt/non hidden bolt
Chans1ee
Thu Jan 04, 2018 8:42 am
Chans1ee View the latest post
There are no new unread posts for this topic. Giro Republic : Using 2-Bolt Cleat Mount with 3-Bolt cleats
gerryc89
Fri Jul 28, 2017 3:24 pm
TheKaiser View the latest post
There are no new unread posts for this topic. How to remove logos on Hylix carbon seatpost
stripes
Sat Mar 04, 2017 3:14 pm
evan326 View the latest post
There are no new unread posts for this topic. How to remove Reynolds freehub Strike SLG wheelset?
poppiholla
Fri Jan 20, 2017 11:52 am
poppiholla View the latest post
Users browsing this forum: darnellrm, Google [Bot], Google Adsense [Bot], jfranci3 and 40 guests
cron
