It is currently Sun Dec 17, 2017 3:52 am
Post new topic  Reply to topic  [ 77 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Thu Aug 03, 2017 10:42 pm
^ A 155lbs Cavendish putting out 1,600w at his max is vastly different than a wet Contador at 135lbs putting out significantly less power at max than Cav. I wouldn't compare those two. If Geoff strips the frame, I bet it is within a few % of a consumer version of the SLR.
PostPosted: Thu Aug 03, 2017 10:50 pm
Ha... I suspect you're probably right on the Emonda, but it's not hard to add a few squares of carbon layup here and there to beef up the most highly stressed points. If the difference is minimal then sure, just stick on a few weights but if an extra layup could make it noticeably stronger, then by all means... gimme that any day over a lead weight.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Thu Aug 03, 2017 11:00 pm
Time did this for Boonen.
www.ergottwheels.com
PostPosted: Fri Aug 04, 2017 1:36 am
I prefer the Emonda.
Sent from my SM-G935W8 using Tapatalk
PostPosted: Fri Aug 04, 2017 3:40 am
I prefer the look of the madone and the weight of the emonda... why can't I have both ?
PostPosted: Fri Aug 04, 2017 2:00 pm
There is a GCN video about Bertie's Emonda and it weighs in at 6,5kg. They say the mechanics add the Velon thingy at the saddle first and then put additional weight on it if needed.
The Velon transmitters add about 200g and are one of the reasons why Trek Segafredo don't get the Madone to the weight limit.
PostPosted: Fri Aug 04, 2017 2:35 pm
@Calnago, yes, his bike is one of the most-recent additions to my collection.
Alberto runs a H1 56, which is fine for me. I would personally choose to run the H1 54 with a 140mm stem, but he prefers a more upright position which is still rideable for me. The saddle height is within 3mm of mine (as measured with the FitStik). The only reason I got the bike now instead of at the end of the season is that they changed the 'viper red' Team livery to white at the Tour.
I have never had a Trek Emonda in my collection before, so I was quite interested to try it. It is a pretty nice bike, that's for sure. Crazy light. I really like the race number holder. Once I get it set-up with SRM, etc., I'll let you know my thoughts.
PostPosted: Fri Aug 04, 2017 3:05 pm
I don't get this choice? If I want a road aero frame I'd choose between various models from different manufacturers, and similarly if I wanted a light-weight climbing frame. The intended use should determine the options, not a common manufacturer (unless I only had one manufacturer's frames to choose from of course).
PostPosted: Fri Aug 04, 2017 3:24 pm
In this case I think the resulting two finalists would for a lot of people end up being the same regardless. Both best in class (aero or climbing) arguably come from the same manufacturer. I'm not into the whole aero thing for my own reasons, but if I were I'd be hard pressed to look further than the Madone. And even though the Emonda SLR is simply too light a frame for my liking, it's the only superlight frame that I would even want to try, simply because I believe Trek to have the R&D resources to pull it off as well or better than anyone. Lastly, the geometry is one that works very well for me, that may or not be the case for someone else. So yes, these would be my two finalists even after looking at all the offerings from all the other manufacturers.
Colnago C60 - PR99
PostPosted: Fri Aug 04, 2017 3:34 pm
Awesome! Might you do a build thread for it as well? Pics! Is it one of the brand new Emonda SLR's or one of the previous generations, with the straighter less profiled downtubes? I think they did a last minute color change simply because there were too many red bikes in the peloton. Love the Viper Red. There were still a lot of Viper Red bikes on top of the team car at the tour. And don't forget to tell the story of how you acquired it in the first place, please.
Colnago C60 - PR99
PostPosted: Fri Aug 04, 2017 3:45 pm
They did a color change just for the tour. The team is back on the red bikes at Tour of Poland and I'm guessing even the Vuelta.
PostPosted: Fri Aug 04, 2017 5:17 pm
Bingo, Calnago nails it. Trek has two of the top frames in their respective categories. If one wants a lightweight climbing bike, the Emonda SLR at $3000 is hard to beat. Same with the Madone and its aero category. While some might not like the integration, its use of the IsoSpeed design puts it at the top of that category.
Not to mention Trek's offering of H1 and H2 fit means most riders can get the exact fit/very close to it that they want. Plus ProjectOne ability to get a unique paint scheme & Trek's lifetime warranty. Many aspects make Trek a very solid consideration now. So I could definitely see one narrowing down their consideration to either the Madone or Emonda and trying to decide which of those two would best fit their riding. Trek has definitely moved back to the cutting edge of the industry with their engineering and composite layup schedule.
PostPosted: Mon Aug 07, 2017 4:13 am
I'm interested in this topic because Trek's new Emonda really appeals to me. I live in a "hilly" part of Indiana and don't see mile long climbs like many people on the forums do, but I feel like the Emonda would be a great crit bike if it's stiff, lightweight, and corners well.
I've never ridden either, which will change soon. Does anybody race the Emonda in crits or road races? I generally make it into some breaks which means I could get value out of the Madone, but how marginal would the benefit be if I'm already running Enve 4.5s? As light as the SLR is, I'm sure it accelerates well so long as the lightness doesn't bring along flex in the BB.
PostPosted: Tue Aug 08, 2017 12:26 am
I was ready to order a 2018 Madone frameset but came up about $1000 short.
I wanted an aero bike since I ride mainly flats, occasional hilly rides.
And I have Trek credit.
I ended up getting the 2018 Emonda SLR frameset, 56, in black/viper red. And got change back ....
I didn't really need another WW bike - my Focus Izalco Max is about 12.6 pounds with Zipp 202 tubulars, 13 with Zipp 303 NSW, pedals and cages, computer mount-included.
If the Emonda rides better I'll be happy, but the Izalco Max is just amazing, so tall order to beat.
So I won't be aero this year ... but I may be able to get the new Emonda up to 1/2 pound lighter with the new Berk saddle etc.
Hopefully, the frame will arrive this week, when I can compare actual vs advertised weight (sore subject between me and Trek)
By next year, I may opt for the Argon 18 Nitrogen Pro instead of the Madone.
PostPosted: Tue Aug 08, 2017 1:15 am
2018 madone h2 price drop to 3500USD. like that glossy clearcoat is back.
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
There are no new unread posts for this topic. Attachment(s) Trek Émonda 2018
[ Go to page: 111 12 13 14 15 ]
hlvd
211
34331
Fri Nov 03, 2017 10:11 pm
ddsg View the latest post
There are no new unread posts for this topic. Low stack top cap for Trek Emonda
Geordiepaul
9
858
Tue Dec 05, 2017 5:44 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. 2018 Trek EMONDA SLR?
Windstopper
21
3847
Sun Oct 22, 2017 7:05 pm
oldnslow2 View the latest post
There are no new unread posts for this topic. Trek Emonda SLR 2018 Rim Brake Build
[ Go to page: 1 2 3 4 ]
ClydesdaleChris
50
3771
Fri Dec 01, 2017 6:51 pm
morganb View the latest post
There are no new unread posts for this topic. Attachment(s) Any thoughts on the 2018 Trek emonda SLR rim brake version?
[ Go to page: 1 2 3 4 5 ]
Windstopper
61
5168
Fri Nov 17, 2017 5:11 am
ClydesdaleChris View the latest post
Users browsing this forum: No registered users and 27 guests
