It is currently Sun Dec 17, 2017 8:56 pm
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Thu Jul 27, 2017 6:30 pm
Online
RyanH wrote:
I think the gold standard for grip in the wet has been Continental (sprinters). I had Vittoria Paves in 28mm which lost traction on turns that I know the Contis would have been fine on. Veloflex has been better IMO too.
I agree, love my Arenbergs. Of course, adjust tubular pressure on wet days (think we should tell that to Sky 2015 :lol: ).
Conti Srinters ( I use the "standard"/slick ones ) are surprisingly grippy on wet surfaces.
Louis :)
PostPosted: Thu Jul 27, 2017 7:04 pm
Well, if tubulars are in the mix, then Continental Comps are my wet weather favorite, but I take along a Veloflex tubular as a spare just in case, since I don't think I could get a spare conti mounted on the road in the wet and cold.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Fri Jul 28, 2017 4:06 am
Hexsense wrote:
And there is a case of Vittoria Corsa G+ which i find their grip is a little bit too good in wet.
Too good in a sense that when wet, it literally pick up every sand, dust, glass it touch along the way. I sometime end up having to remove glass or big piece of sand from the tire along the vertical groove after the ride or big shop stop before it do any damage to the tire. My other wheel on the same bike with Continental 4000sII is noticably cleaner. But that's not too bad as i normally ride in dry and this only happen in wet so i'll still keep using the Corsa G+ as the comfort and cornering grip is just so good.
Good to know!
I really disliked all my Vittoria Open Corsa (not G+) in the wet. They really did not have much grip
PostPosted: Fri Jul 28, 2017 12:23 pm
mogwaiboi wrote:
I use Michelin Pro4 Endurance/Service Course 25c on the winter bike and have found them to be quite good. I purchased a bunch in bulk as I found them online for $28 AUD. I would use 28c if my frame allowed (they do run wider than advertised though). Never had any problems in the wet on bike paths here in Australia with wooden bridges, etc. I've also used Schwalbe Durano on the same bike and rate them highly.
Third on the Michelins.
PostPosted: Fri Jul 28, 2017 5:56 pm
Good to know!
Yeah I was also surprised because I had a few hairy moments in wet with the the vittoria g+ tubs. But maybe it was just bad luck.
PostPosted: Fri Jul 28, 2017 6:53 pm
nemeseri wrote:
Good to know!
Is the road clean?
It maybe dust and sands on the tire at bad angle. Which is... again the problem of this tire.
Why is it so attractive to all road debris?
PostPosted: Sat Jul 29, 2017 10:50 am
A very soft compound most likely. You should be able to check it with a durometer if useful.
Ride it like you stole it
PostPosted: Sat Jul 29, 2017 7:54 pm
Go for the Schwalbe Durano's. Very good grip, like if you are riding on rails...
The rubber doesn't pick up any small stones or sharp pieces and the wearing is very low.
In terms of rolling resistance, they are not too bad, maybe slighty more than the GP4000s II. It is a very comfortable tyre too.
I am using the 25mm and they are really perfect as winter, bad weather / rough roads training tyres.
All in all, this tyre will give you a lot of confidence.
CAAD 10 2015
PostPosted: Sat Jul 29, 2017 8:00 pm
+1 for Pro4s, Service Course or Endurance. Never any issues with traction on any terrain.
PostPosted: Sat Jul 29, 2017 9:30 pm
kidrob wrote:
Very happy with my Conti 4 Season 25mm all winter
Another vote but with bolt statement of harsh ride. These run true to size (e.g. 25mm on wide rim), great wet grip and puncture resistance. Overall, it's a great training tire for foul-weather only. You gotta be crazy to run these when sun is out. Unfortunately, 28mm are not any wider. In other word, they also measure 25mm wide.
:nospamhere:
PostPosted: Sat Jul 29, 2017 10:35 pm
My 28c Conti 4 seasons measure up at between 28mm and 28.3mm on a 19mm internal width rim. I fully recommend them. After a full winter of commuting with them the only puncture I got was a pinch puncture when I jumped a curb with an under inflated rear.
PostPosted: Sun Jul 30, 2017 12:44 am
Anyone got any feedback on vredestein fortezza all weather?
Chapter 2 Tere
PostPosted: Sun Jul 30, 2017 1:15 am
Thank you all for the recommendations. After reviewing the rolling resistance data and the favorable reviews by fellow members, I think michelin nailed it with the pro4 series. I will definitely give them a try.
I'm kind of surprised nobody used / mentioned challenege tires...
PostPosted: Sun Jul 30, 2017 3:11 am
Rolling resistance from which source? www.bicyclerollingresistance.com is using the drum.
:nospamhere:
PostPosted: Mon Jul 31, 2017 2:03 am
Yeah, Drum test put force on the drum and measure loss of energy from the drum. This is quite accurate for front wheel.
But for rear wheel, in real world force are from the wheel to the tire to the ground. When the drum are rough (to make it more similar to real road) there are some difference. Harsh tire on rough road/drum make the wheel jump and skip. During that short time, resistance measured on the drum gone down (maybe to zero). While suppler tire conform the rough road better and skip less so it has shorter time where the resistance disappear, this will read as more resistance. In real world, Jumping up and down or skip means momentary loss of power transfer and that means less energy transferred to the road which put penalty to the rider.
There are no new unread posts for this topic. Garmin 820 navigation doesn’t stick to roads / acts like aerial navigation
dorin
13
726
Tue Nov 28, 2017 1:38 pm
dorin View the latest post
There are no new unread posts for this topic. Winter tires recommendation
CallumRD1
Mon Oct 09, 2017 4:37 pm
CallumRD1 View the latest post
There are no new unread posts for this topic. Textured Tires on trainer
misterq
Sat Sep 16, 2017 10:38 am
Kaboom View the latest post
There are no new unread posts for this topic. Attachment(s) Tubeless road tires don't work for everyone - discuss
[ Go to page: 116 17 18 19 20 ]
Lewn777
290
17245
Sun Dec 17, 2017 10:22 am
bm0p700f View the latest post
There are no new unread posts for this topic. Fast, light 700x20c tyres / tires?
kman
Mon Jan 02, 2017 11:44 am
kman View the latest post
Users browsing this forum: albertop07, Bing [Bot], erik$, Google Adsense [Bot], kavitator, KCookie, KLabs, lovemyway, saverin and 41 guests
