It is currently Thu Oct 19, 2017 3:08 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 Next
 Post subject: Carbon Stem Supporters
PostPosted: Mon Jul 24, 2017 4:30 am
I know that many a times, people favor the stem made from alloy more than carbon. I am keen to know how many here actually tried and support the use of a carbon stem. Do you find it better as in stiffness/weight/absorb more buzz from uneven road?
I just recently switched over from 3T Arx Team Stealth to 3T Arx Ltd carbon stem and i instantly can feel a different to the bike handling and buzz from the uneven roads. I do know that people also say that tire pressure or wider tires play a bigger role in these but i would love to keep everything the same and just by switching the stem to see what's the stem did to the overall feel.
PostPosted: Mon Jul 24, 2017 6:34 am
How is the carbon stem different what do you feel ?
BMC TMR01 --> viewtopic.php?f=10&t=131523&hilit=tmr01
Colnago Master X Light --> viewtopic.php?f=10&t=140479
PostPosted: Mon Jul 24, 2017 6:38 am
I feel safer with carbon integrated bars+stem compared to alloy stem and carbon bars. It's too easy to damage the bars clamping area I've noticed. Including screws just 250gr, not bad. 40-50usd.
/a
PostPosted: Mon Jul 24, 2017 6:56 am
The first thing i feel is that on the same route i frequently ride on, those area that i feel alot of road buzz felt more smooth now. All i did was change the stem from alloy to carbon and nothing else.
PostPosted: Mon Jul 24, 2017 7:06 am
Online
Now do a blind test
PostPosted: Mon Jul 24, 2017 8:12 am
silvalis wrote:
Now do a blind test
I did something sort of like a blind test as i have switched back the alloy to double confirm my results. I would say maybe the effect is very small as compared to other parts but it still does control the road buzz better than alloy stem. Small effect is better than no effect for me and also i find that going long distances, this helps even more as a little bit of comfort goes a long way down the road if i am having a ride of more than 100miles
PostPosted: Mon Jul 24, 2017 10:59 am
Administrator
I ride a 3T ARX LTD stem. Not the lightest at 121 grams for 100mm but it does look good with my 3T Aerotundo LTD bars. They are both just a great riding combination for me.
RESIDENT GRUMPY OLD MAN.
PostPosted: Mon Jul 24, 2017 11:07 am
I've been using 3T Ltd for couple of seasons. After changing to aluminium stem, with the other components remaining the same, I didn't notice any differences.
Cervelo S5
Cervelo R5 VWD 5637g/12.43lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Mon Jul 24, 2017 12:20 pm
The only one that I've been able to really notice a difference on is the Zipp Sprint stem. It makes a noticeable difference in handling feel on the limit and out of the saddle climbing/sprinting because it is so much stiffer than a standard stem. It isn't light and I don't notice any vibration dampening though.
PostPosted: Mon Jul 24, 2017 12:30 pm
tires are soft and squishy
stem is tiny, compact, relatively beefy....... detect a material change in the stem itself? no, i cannot
PostPosted: Mon Jul 24, 2017 1:03 pm
After I switched to carbon stem and carbon handlebars I am never doing aluminum again in those two areas. This is why:
Since your hands are always on contact with the handlebars these is a critical area for hand and upper body fatigue.
1st I did the handlebars. I was amazed at the improved level of comfort. Vibration is reduced considerably and your arms feel less beaten up. I got the Thomson handlebar bc they are one of the lightest and they are made of a complete piece. Not like many others at that time (4 years ago) that were put together by pieces and reattached. I saw many of those crack badly on accidents since these attaching points are weaker.
I have been on many accidents and the bars are going strong. In one of those the bar cracked the frame and the bar is still going.
2nd after being so impressed with the handlebars I decided to do the stem. I went with the Easton ec90. The result was dramatic! The cockpit became like butter. So pleasant. And it is stiff. Not as stiff as an full aluminum cockpit but barely noticeable. There is an initial give and after a certain point there is no more. I noticed this at the beginning. After a while it is part of how the bike handles.
With aluminum there was no give. The Aluminum cockpit is harsh and unforgiving. I will only use aluminum in a track bike where the surface is smooth.
I was afraid regarding durability but so far so good. I am a big rider 195-205lbs. I have had many accidents which has resulted in 3 cracked carbon frames. The cockpit has survived 2 of those and no issues in 4 years.
This is the ride. You can't see the Thomson logo but you can see the EC90 stem. Good luck
PostPosted: Mon Jul 24, 2017 3:16 pm
I have been on the 3T equipment for a while now between all the models. The LTD stems are undeniably more stiff and do cut a little road vibration out. However it's stiffness can add a harsh edge to your bike depending on the setup. As an example I had an LTD slammed on a rather stiff frame and wound up having to put the Team model on just to make the ride more comfortable. Either way both good stems and worth noting only a couple grams in between.
Just ride ..
PostPosted: Mon Jul 24, 2017 8:12 pm
I ride with a Time carbon stem and handlebar set for the last few months and I also feel that it was a considerable upgrade in comparison to anything I had ridden before (alu Ritchey wcs stem - alu wcs bar, carbon superlogic stem - alu wcs bar). For the first time I can feel a combo that it is very stiff and really comfortable at the same time.
Of course the quality of carbon and its way of manufacturing matters as well, all carbon stems and handlebars are not the same.
My 6708gr TIME Skylon
My 9733gr COLNAGO Master X-light
PostPosted: Mon Jul 24, 2017 8:29 pm
PostPosted: Mon Jul 24, 2017 10:26 pm
Zipp, Enve and 3T claimed they made carbon stems due to demand, not performance enhancing.
I have rows of stems, latest is Shimano Pro Sprint. It was sworn to offer vibration damping, haha... loads of BS.
It's stiff i'll give it that (56mm wide bar clamping). But what to expect with a stem of 210 grams at 105mm!
The front lid alone is 48 grams!
Make of it what you want, some alu stems have sharper edges and in some cases this can give marks at carbon bars.
At 14 stems i think i could easily use a 3T alu stem (if we only talk performance).
Some suggestions says a lower stem is stiffer (=not me!).
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
There are no new unread posts for this topic. RR1.0 SL Carbon Bar/Stem - 420 in 120mm?????
Vallinotti
Tue Oct 25, 2016 10:08 pm
Vallinotti View the latest post
There are no new unread posts for this topic. Bar-Stem combo: alloy or carbon?
MiddMan
22
2095
Mon Oct 02, 2017 7:32 pm
nemeseri View the latest post
There are no new unread posts for this topic. Nice carbon bar and stem setup?
PLuKE
11
1164
Wed Aug 23, 2017 6:09 pm
PLuKE View the latest post
There are no new unread posts for this topic. Paging those with a Pro Vibe Sprint Carbon stem
tharmor
Sat Aug 26, 2017 4:06 pm
Ezra View the latest post
There are no new unread posts for this topic. Cannondale CAAD10 - Stem Torque for Carbon Steer
steelandbananas
9
860
Sat Feb 11, 2017 6:11 pm
Hamfist View the latest post
Users browsing this forum: bikerjulio, Bing [Bot], Drpoomanchu, jcjordan, JeffK and 38 guests
