It is currently Tue Oct 17, 2017 3:36 am
Post new topic  Reply to topic  [ 9 posts ]
 Post subject: Pedal stack
PostPosted: Sat Jul 22, 2017 9:44 am
Hi, I've two bikes, both same frames but one has Look Blades and the other has Garmin Vectors.
The stack on these is 13mm and 17mm and have measured from the pedal plate up to the saddle so both measurements take into account the difference, one being 4mm less.
Now, is this the correct way to do this as the distance from BB to saddle top will be the same and if I've done it correctly, distance to pedal spindle will also be the same.
Hope I've made that understandable, thanks.
 Post subject: Re: Pedal stack
PostPosted: Sat Jul 22, 2017 10:20 am
pedal stack is measured from spindle axis to the sole of the shoe (at closest point)
all else being equal, you'd set the saddle on the garmin equipped bike a bit higher wrt to bb axis to compensate, this has a slight knock-on effect on saddle fore-aft position, but unlikely to be enough to matter
PostPosted: Sat Jul 22, 2017 11:26 am
So you're saying distance from BB to saddle should be the same on both bike's and distance to pedal plate different due to 4mm difference?
PostPosted: Sat Jul 22, 2017 11:29 am
I would love to see how i would end up on a bike fitted by five fitters compared to how i sit.
Just looking at saddle height, setback and cleat position.
Does cleat position differ anyway for setback?
I see many team riders start to sit more forward, ladies seems to have more setback for some reason?
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
PostPosted: Sat Jul 22, 2017 11:38 am
no
i said "set the saddle on the garmin equipped bike a bit higher wrt to bb axis to compensate"
that's if you want same leg extension at the bottom of the stroke
i also said "all else being equal", if there's any variation in geometry/size between the two bikes, the effects of that also need to be taken into account
PostPosted: Sat Jul 22, 2017 11:39 am
Haha, which is exactly what I've written in my initial post, in a very roundabout way :D
PostPosted: Sat Jul 22, 2017 11:45 am
no
Ok, sorry if I sound confused, I am, but all my fault.
Top of saddle to pedal axle is same on both at the moment, but difference in 4mm less on the Vectors from saddle to pedal plate to account for higher stack.
Both frames exactly the same.
Thanks for your patience.
PostPosted: Sat Jul 22, 2017 12:00 pm
it's ok :)
the point is this: the increase in garmin pedal stack raises your foot by 4mm with respect to the bb axis
therefore you need to raise the saddle if you want the same maximum leg extension at the bottom of the stroke as what you have with the look pedals
if you imagine a stupidly extreme case where you had not 4, but 400mm pedal stack, see what it does to your leg extension? you would need to raise the saddle a lot to compensate (of course it'd be a terrible ride due to the long lever connecting your feet to the pedals!)
PostPosted: Sat Jul 22, 2017 12:03 pm
sungod wrote:
it's ok :)
Thanks for your patience, I'll adjust one later.
Many thanks
There are no new unread posts for this topic. Look pedal removal - allen key vs pedal wrench?
mvcap
Thu May 11, 2017 1:40 pm
Geoff View the latest post
There are no new unread posts for this topic. Stack and Reach question
Lookryder
11
727
Fri Sep 01, 2017 12:23 pm
silvalis View the latest post
There are no new unread posts for this topic. New shoes... reduced stack height
girona
Thu May 25, 2017 12:25 pm
kkibbler View the latest post
There are no new unread posts for this topic. San Marco Regale Carbon FX Stack Height
Stolichnaya
Thu Dec 29, 2016 3:29 am
Denavelo View the latest post
There are no new unread posts for this topic. Pedal q-factor
superb
Thu Nov 03, 2016 9:21 pm
travs View the latest post
Users browsing this forum: Baidu [Spider], benjaminm3, CBRE, chiumomo, Google Adsense [Bot], kookie and 36 guests
