It is currently Fri Dec 15, 2017 10:58 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 Next
PostPosted: Fri Jul 21, 2017 1:24 am
without getting into the pros and cons of disk brake road bikes, has anyone managed to build up a sub 6.5 kg bike? what about a truly weight weenie build?
PostPosted: Fri Jul 21, 2017 2:10 am
Someone in HK built a Open UPPER with all exotic parts
THM crank
Six-Spoke wheels (bike ahead)
Carbon rotors (SiCCC can't find it retail now)
R9170
PostPosted: Fri Jul 21, 2017 2:41 am
The Focus Izalco Max Disc with Red comes in at 6.83 kg. The dt rc 38 wheels are over 1400g so without much fuss I think that'd easily be sub 6.5kg.
Strava
Current Stable. The Snob Machine | The Crumpton
The Ex's. LS Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | LS Xicon: 5.76kg | C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg | Evo - 5.18kg | LS Classic - 6.7kg
PostPosted: Fri Jul 21, 2017 3:02 am
I'm building a SS EVO HiMOd Disc with Etap HRD, frame should be here in a few weeks but everything else is ready go. Might do a build thread for this one as there aren't many for disc bikes yet.
Haven't weighed everything but based on a mix of actual and claimed weights it should end up around 6.3kg. Only truly exotic WW part on the bike will be the Berk saddle.
PostPosted: Fri Jul 21, 2017 4:24 am
@DOUG pls do. would love to see your build. what would be the wheelset?
PostPosted: Fri Jul 21, 2017 4:59 am
The pics no longer work, but there is this one 6.47kg
viewtopic.php?f=10&t=139085&p=1227186&hilit=storck+disc#p1227186
Website | Instagram
PostPosted: Fri Jul 21, 2017 5:12 am
@jlok. Wheelset is Bontrager Aeolus 3 TLR D3 clincher. Still need to weigh them but should be around 1450g for the pair.
I'm hoping for 6.3kg but would be happy with 6.5kg which would still be 1.3kg lighter than my CAAD10 Black Inc Disc.
PostPosted: Fri Jul 21, 2017 10:24 am
use this di2 combo: ST-R8070-L+ST-R8050-R or ST-R9170-L+ST-R9150-R - this sti have same shape
get front disc wheel (20h lacing 2x/1x no brake track) and rear rim brake wheel
saves a lot of rotating weight on rear spokes
you get extra stopping power and extra modulation where you really need (front)
you can save rear wheel brake track most of time (when it's safe to use front disc as primary brake)
saves your time on rear wheel operations, no need to re-align rear rotor
this will not work with mechanical shift, because mechanical sti for disc and rim sti have different shape
PostPosted: Fri Jul 21, 2017 11:03 am
I'm interested in seeing this.
Which wheels will you be using? I'm looking for some wheel inspiration.
My bike has DT Swiss R23, about 1700g, bike is currently 7.3kg(inc pedals & Garmin) so absolutely no WW. I'd like to get it to about 6.8kg - just because.
PostPosted: Fri Jul 21, 2017 11:11 am
:oops: sorry for asking question you've already answered...Bontrager Aeolus 3 TLR D3
PostPosted: Fri Jul 21, 2017 2:57 pm
Here's my 6470g Storck.
PostPosted: Fri Jul 21, 2017 7:42 pm
How are the Biturbo wheels compared to standard spoked carbon wheels?
In anyway harsh riding?
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
PostPosted: Fri Jul 21, 2017 8:56 pm
My L size U.P.P.E.R. 5.99kg without pedal
Shimano/Schmolke Carbon/Tune/CeramicSpeed/THM/bike ahead Composites
Speedvagen Road Disc 7.9 kg | Open U.P.P.E.R. 6.x kg | Open One+ 7.7 kg
PostPosted: Sat Jul 22, 2017 3:48 am
Cube make one the C:68 SLT Disc.
Manufacturers claimed weight is 6.6kg
https://www.cube.eu/en/2017/road-triath ... lack-2017/
PostPosted: Fri Oct 20, 2017 4:36 pm
Anyone who can give a review of the bike ahead biturbo wheelset? I am sure they will look good on my roadmschine.
There are no new unread posts for this topic. Worried by industry pro disk brake propaganda filtering through cycle media
[ Go to page: 14 5 6 7 8 ]
Lewn777
105
9220
Tue Sep 19, 2017 12:20 pm
thumper88 View the latest post
There are no new unread posts for this topic. Attachment(s) XTR brake calipers on a road bike
Ticlimax
30
2527
Wed Jul 26, 2017 3:42 am
ms6073 View the latest post
There are no new unread posts for this topic. Building a disc brake bike
L3X
26
3113
Fri Dec 23, 2016 11:51 am
Broady View the latest post
There are no new unread posts for this topic. Lighten Hydraulic Brake Bike
Fatclimber
32
2891
Mon Dec 04, 2017 8:12 am
addict View the latest post
There are no new unread posts for this topic. Rim brake bike with 25mm tire and fender clearance
nemeseri
24
1832
Mon Jul 31, 2017 2:40 pm
Multebear View the latest post
Users browsing this forum: fbonde, wingguy and 40 guests
