Rebuilding Sram HydroR calipers
by MayhemSWE
Has anyone rebuilt a Sram HydroR disc caliper with new piston seals?
I have a Rival post mount caliper with a sticky piston where no amount of piston advance, cleaning or lubrication seem to help. Unless anyone has further ideas for me to try I am now looking at buying service kit 11.5018.029.000 and replacing the piston and seals.
Fitting new seals without disassembling the whole caliper seems difficult, but what I am concerned about is how the two halves of the caliper fit together. Is there an o-ring or other form of seal where the fluid passes between the halves? It is not obvious from the spare parts catalogue but no additional seals seem to be included in the service kit or otherwise available.
by jlok
by bikewithnoname
Like the mtb calipers the fluid goes through the banjo bolt, not the caliper shell per se, there will be 3 or 4 o-rings on that bolt. Rebuilding is simple, and the road calipers will let you remove the pistons without cracking the calipers in half if you have the right red block spacer thing. Be sure to keep the fluid off your paint
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
