Bottom Bracket Assistance
JScycle
by JScycle
Hi All,
I have a 2016 Scott Addict with what I assume is a BB 86.
I currently have an Ultegra crankset but if I was to switch to another company such as Sram would I need GXP or BB30 cranks.
Also would I need a different bottom bracket.
Any measurements and information would be awesome
p3dalfaster
by p3dalfaster
For the Scott's, you will need the SRAM PF GXP 86.
http://www.chainreactioncycles.com/sram ... d|291564UK
JScycle
by JScycle
p3dalfaster wrote:For the Scott's, you will need the SRAM PF GXP 86.
Thankyou, so does that mean I need the Sram GXP cranks?
bikerjulio
by bikerjulio
Without going into a long explanation - yes, if you wish to use a SRAM crankset. And a GXP BB to go with the frame.
There's sometimes a buggy.
One.
JScycle
by JScycle
Thankyou, so what is the difference in shimano spindles and sram gxp spindles?
havana
by havana
Shimano is 24 mm.
Gxp is 24 mm on one end and 22 on the other (it's tapered).
Most "innovations" in cycling are solutions for non-existing problems.
bikerjulio
by bikerjulio
Well actually it's stepped, not tapered.
The NDS bearing has a nominal 22 mm bore and the step on the spindle butts up to it. When the spindle bolt it tightened a lip on the crank contacts the inner race, clamping onto the bearing, thereby holding the spindle laterally.
One.
JScycle
by JScycle
bikerjulio wrote:Well actually it's stepped, not tapered.
Thanks so much!
