It is currently Tue Jan 23, 2018 1:40 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 Next
PostPosted: Tue Jul 11, 2017 5:20 am
Hello weenies...
A friend is getting ready for the Taiwan KOM climb and is worried of burning out and having to walk the bike the 27% grades at the end as well as not finishing within the 7h time limit. He likes to spin and just dislikes being out of the saddle.
He's on a wilier running campy veloce 10s with a compact crank 50/34 and a 12-30t cassette. The derailleur is already the longest available thats compatible (medium) and looks to be at the limit on the 30t cog. Not much space to fit even a 32t which isn't available from campy (campy freehub).
To the point. I saw on youtube you can fit an mtb crank on there. The problem is the chainring size. Double chainring cranks are usually maxed at 42/28t and we would like a 46/28 or 46/30. Do you have an idea which common crank can be fitted with such rings and could work on a 10s road bike?
He has a clamp on front derailleur that can be lowered appropriately. I've been looking to get an mtb crank in an appropriate bcd and switch a chainring if needed. What do you think?
Thank you for reading!
/a
PostPosted: Tue Jul 11, 2017 5:58 am
46/33 on compact 110bcd is definitely doable.
mtb cranks have higher Q-factor, no?
Less is more.
PostPosted: Tue Jul 11, 2017 6:28 am
Look at those new fsa and praxis sub-compacts.
46/30 and 48/32
Chapter 2 Tere
Scott Spark 720plus
PostPosted: Tue Jul 11, 2017 7:39 am
If you really want to fit an MTB crank (higher Q factor but most ppl don't notice) you can get *all* ring sizes from Specialites TA.
PostPosted: Tue Jul 11, 2017 8:23 am
I replaced a Shimano compact with a 46/30 FSA Omega (2017) on my wife's road bike. Only gotcha is that you have to replace the bottom bracket since the FSA has a 19mm spindle, which also implies that there are not a lot of bottom bracket options (only the ones from FSA themselves). They also have a pricier version (SL-K adventure).
Overall we're very happy with it. Much better solution than having to fit a cassette with large gaps between gears.
PostPosted: Tue Jul 11, 2017 8:56 am
What do you think would happen if you get for example a 3 ring crank like 48/36/24t and take out the 36, put the 48 on it's place and swap out the little one for a 30t (64bcd).
An outer ring being used as a middle ring. How would that work?
/a
PostPosted: Tue Jul 11, 2017 9:50 am
I think your chainring spacing will be way out.
Chapter 2 Tere
Scott Spark 720plus
PostPosted: Tue Jul 11, 2017 10:15 am
All the spotfaces on the chainring will be wrong, ring spacing *should* be ok. But chainline might be odd.
PostPosted: Tue Jul 11, 2017 11:24 am
Rotor announced a 46/30 chainring set that mounts to their cranks but I have only seen one set in the wild.
PostPosted: Tue Jul 11, 2017 12:13 pm
/a
I did this on my old CX, riding 26/40 and 30/40 with a FSA Gossamer triple and TA rings. Shifting was *excellent*.
Because of the positive experience, I just did the same for my wife's new (all-)road bike, she now has an FSA SL-K carbon triple crank with the 26/40 combo and an 11-32 in the back.
PostPosted: Tue Jul 11, 2017 12:36 pm
I had a Campy 10-speed cross bike that was used on trails. Ended up with a Deore crankset and needed a Deore FD as well. The stock FD will foul the chainstay before being low enough. Everything worked fine.
There's sometimes a buggy.
One.
PostPosted: Tue Jul 11, 2017 2:18 pm
/a
What was source for 40T chainring?
Was it chainring for big or middle position originally?
PostPosted: Tue Jul 11, 2017 2:31 pm
Specialites TA. Middle ring.
PostPosted: Tue Jul 11, 2017 2:42 pm
On Rotor crankset, it's possible to change the spider for the MTB one, 110/74 (or 60, Rotor proprietary). You keep the road Q factor, have the possibility to have less than 30t on the inner.
PostPosted: Tue Jul 11, 2017 4:42 pm
Didn't realize they were interchangeable, good to know as I primarily run Rotor cranks due to them offering shorter lengths. On a similar vein TA Specialites cranks allow you to do the same, although they are square taper.
There are no new unread posts for this topic. Attachment(s) Dura Ace 9100 Crank on Boardman 6.84kg bike
Kevinch76
Fri Jul 28, 2017 4:39 am
CycloTron View the latest post
There are no new unread posts for this topic. TT saddle on a road bike ?
destinationwarmth
Fri Aug 11, 2017 8:35 pm
Multebear View the latest post
There are no new unread posts for this topic. Hanging a Road Bike
ohyeah22
23
2374
Thu Nov 02, 2017 9:35 pm
Zakalwe View the latest post
There are no new unread posts for this topic. Ritchey Road Logic as second bike..
[ Go to page: 1 2 3 4 ]
3Pio
45
3641
Thu Dec 21, 2017 7:49 am
3Pio View the latest post
There are no new unread posts for this topic. 2017 Road Disc Bike - what would you get?
[ Go to page: 14 5 6 7 8 ]
djgarrett21
110
18395
Wed Jan 03, 2018 8:43 pm
BearCrawl View the latest post
Users browsing this forum: Bing [Bot], cycleboyco, dricked, Hexsense, joejack951, Majestic-12 [Bot] and 40 guests
