Issue with 4iiii left side power meter
mustafah009
by mustafah009
Hi,
As anyone had any issues when calibrating a left side only 4iiii power meter?
Since a few days ago I'm always getting error 20 in my Garmin when calibrating the PM and an error when doing the same in the 4iiii's iphone app. PM still sends data to the Garmin, both power and cadence, its just the calibration that fails everytime.
Thanks
gmarsden
by gmarsden
Instead of displaying zero offset values, a simple 10 indicates that everything is good to go. Below is a list of status values and their meaning.
10 – Good, ready to ride
20 – Unstable data (bike not stationary)
30 – Low battery (less than 10%)
50 – Calibration error – contact support
mustafah009
by mustafah009
gmarsden wrote:Instead of displaying zero offset values, a simple 10 indicates that everything is good to go. Below is a list of status values and their meaning.
Thanks.
I'm getting 20 in all tries. Bike is stationary and cranks in the correct position. Have you ever experienced this?
kulivontot
by kulivontot
Try it from the phone app
beanbiken
by beanbiken
kulivontot wrote:Try it from the phone app
Initial post says he has
Ahhh, coffee & carbon
mustafah009
by mustafah009
The app doesn't show any code but still doesn't work, just tells me to try again.
kulivontot
by kulivontot
Was it once paired to a right crank arm? I had issues when i separated the cranks but did not manually unlink them in the app
mustafah009
by mustafah009
kulivontot wrote:Was it once paired to a right crank arm? I had issues when i separated the cranks but did not manually unlink them in the app
No. Nothing changed in the setup.
Also tried a new battery but same result.
I think the next step is to send the unit to 4iiii.
mustafah009
by mustafah009
Update: 4iiii's support couldn't identify the problem (truth be told they didn't even tried) and now I will send the unit back for repair.
Weird thing is that the power data being sent to the Garmin is still very in line to what I was expecting but the error 20 is always there.
waltthizzney
by waltthizzney
did you take the battery out? update the firmware?
mustafah009
by mustafah009
waltthizzney wrote:did you take the battery out? update the firmware?
Yes, I've tried two new batteries and don't have any firmware available to try from the app.
It's weird that 4iiii doesn't include any debugging tool in their app neither somethingg like factory reset. It would be really helpful in this case.
AZR3
by AZR3
So even sending that error code it still gave accurate power readings? Were you ever able to get it calibrated and working or did it just send out the error code from the start?
mustafah009
by mustafah009
AZR3 wrote:So even sending that error code it still gave accurate power readings? Were you ever able to get it calibrated and working or did it just send out the error code from the start?
Yes I've compared the data with my tacx neo and the readings are close, like they were before the issue.
I always calibrate the unit before each ride and since I bought it in February it was calibrating fine (code 10 in Garmin). This just started last week.
hollandgdavid
by hollandgdavid
mustafah009 wrote:Hi,
Thanks
Hi, I have also just started having this same problem with my 4iiii left sided. Pretty much exactly the same apart from my power readings are also off. Have you gotten any further with getting it fixed? Did you send it off for repair?
Tohan
by Tohan
I have started having this same problem where it only calibrates to 20, won't calibrate from the app and the power data is a lot lower than what it should be. Was there any fix for this in the end or was it just replaced by 4iiii as mentioned above?
Cheers
