It is currently Tue Jan 23, 2018 1:23 am
Post new topic  Reply to topic  [ 41 posts ]  Go to page 1 2 3 Next
 Post subject: Hope RX4 Caliper
PostPosted: Sat Jul 08, 2017 1:54 am
Anyone has experience with the new Hope caliper? I did a search and found several topics regarding their introduction, but no one seems to have used it.
I'm using the RS785 calipers on my cx/gravel/winter bike, but really don't like the drag and pingings. I have read that pistol retraction is an issue on the R/RS785 calipers. Exploring the options of using XTR caliper or these new RX4 caliper.
Thanks.
 Post subject: Re: Hope RX4 Caliper
PostPosted: Wed Jul 19, 2017 8:22 pm
Also very much interested to hear if anyone has picked these up yet. Though announced long ago I don't think they've been available to buy until pretty much now? At least I haven't seen them listed at any retailer until just now when Bike 24 says they can source the post mount versions from Hope in 5-8 days (flat mount versions not listed yet though). Personally I'm dealing with sticky pistons and pad clearance on a Rival equipped bike so my own interest is primarily in the Sram/DOT5.1 version…
PostPosted: Thu Jul 20, 2017 12:52 am
If you are already on the Shimano system and want a 4 pot Post mount caliper, go with the Zee. I have and they work great with the RS685 levers. Great lever feel and modulation.
I'd love to see how the RX4 calipers go too, but are they only the DOT fluid ? - Oh, just looked at the Bike24 blurb, and they are making them for each fluid type. Nice.
What piston sizes are they ?
Would they require a different hose/connectors to fit to the Shimano RS685 levers when compared to the R785 calipers (i.e. plug & play) ?
PostPosted: Thu Jul 20, 2017 1:57 am
This is weightweenies, no Zee/Saint calipers are allowed -- at least not on my gravel/allroad bike. :)
If I don't get any real feedback on the RX4, I'll probably just go with XTR M9020 calipers. ~103g each.
PostPosted: Thu Jul 20, 2017 11:20 am
RX4 flatmount available soon apparently, I'll be getting as soon as available.
PostPosted: Thu Jul 20, 2017 11:30 am
Check out Hope's website, they have PDF's available for the instructions and parts diagrams:
http://www.hopetech.com/product/rx4-caliper/
Piston sizes are not listed anywhere but are different between the Shimano and Sram versions to compensate for different master cylinder sizes. Judging by the part numbers, the large piston on the Sram version is the same as the small piston on the Shimano version! As a consequence of this the size of the brake pads are also different.
From my understanding of the installation instructions you can keep the original hose but will need to cut it and install a new Hope fitting.
PostPosted: Fri Jul 21, 2017 12:02 am
@justaute - from a WW perspective, got it, but the Zee/RX4 weights are close - Zee Caliper (bare) : 127g ea, Shimano pads, springs & split pin : 24g (set - unfinned) & Uberbike pads, springs & split pin : 23g (set).
The RX4 Shimano version uses the Tech 3 E4 pads which are deeper (37 x 29mm) than the Zee pads (39.5 x 24.2), but slightly shorter, so matched there.
Couldn't work out the pad size for the SRAM version.
If the hose length is long enough, then it seems a pretty easy install if you want a 4 piston caliper !!
PostPosted: Fri Jul 21, 2017 12:12 am
Edit didn't work ...
I guess the other HUGE bonus, is that the spares are theoretically available !!
Just found the details on the piston diameters here. Note this is from 2012, so doesn't have latest calipers like Tech 3 E4.
SRAM verwsion uses 14 & 11mm (same as Mon 6 pistons), and Shimano version uses 16 & 14mm from Mono M4.
Interesting comparison, is that the Zee/Saint calipers use 18 & 16mm pistons, but they still work well with the RS685 levers !!
Hmmmm, something to play with in the future ?
PostPosted: Fri Jul 21, 2017 2:30 am
Thanks for all the information, MichaelB. Interesting stuff. Didn't think Zee would be that light.
To me, I don't need more power. I want better, more consistent piston retraction. My current RS785 is good enough as far as power goes, but retraction isn't good and they are heavy.
PostPosted: Fri Jul 21, 2017 3:51 am
NP. Have always found it hard to get info on the piston sizes.
BTW, the Hope Tech 3 E4 caliper uses 16mm pistons (x4), but is built for DOT fluid only.
PostPosted: Fri Jul 21, 2017 9:30 am
PostPosted: Fri Jul 21, 2017 12:33 pm
Do these only work with 160mm rotors?
PostPosted: Fri Jul 21, 2017 1:13 pm
For flat-mount, that's the case.
PostPosted: Fri Jul 21, 2017 7:59 pm
Postmount does also work with 160mm Rotors.
Agree with you justaute, they don't retract as well as i would like, but braking power is clearly sufficent for hard ass gravel.
It's way to easy to get pad rub and when changing wheels i often need to adjust the calipers.
Not to mention if it's mud and gravel spraying right into the calipers, it both squeel and rubs.
I guess both R and RS 785 retracts just about same same?
Isn't it just the way the brake hose is attached which is the difference?
Anyway, i have the RS version.
Would be really nice if anyway had the Hope versions.
I contacted two dealers in EU, but none had any hands on experience with them.
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
PostPosted: Fri Jul 21, 2017 9:14 pm
FWIW...based on my exchange with Hope, via FB Messenger, I'm not sanguine about its customer service; thus, at this point, not high on its product. I want to give my business to a smaller company like Hope, but the company does not seem to want it.
I'm wondering about TRP's new brake system. I've received excellent customer service from TRP, at least here in the US.
There are no new unread posts for this topic. need a lighter front brake caliper
addictR1
Mon Nov 13, 2017 4:52 am
addictR1 View the latest post
There are no new unread posts for this topic. Lightest mechanical disc brake caliper?
alcatraz
10
1253
Wed Aug 30, 2017 3:36 pm
joejack951 View the latest post
There are no new unread posts for this topic. SRAM Red rear brake caliper problem
itguy
Wed Jan 10, 2018 12:41 am
itguy View the latest post
There are no new unread posts for this topic. Caliper: Tiagra 4700 vs Ultegra 6700
WiryMike
Mon Feb 27, 2017 4:31 pm
hambini View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo Chorus rear caliper stone damage??
Boshk
7
529
Tue Jan 16, 2018 2:14 pm
Boshk View the latest post
Users browsing this forum: caad4rep, Google [Bot], Google Adsense [Bot], jinchou2000, JS300, Majestic-12 [Bot] and 39 guests
