It is currently Thu Oct 19, 2017 3:07 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Fri Jul 07, 2017 8:09 pm
I am upgrading my road bike to the new Shimano 9150 Di2 system, and at the same time I am adding a Quarq DZero power meter (while trying to minimize the weight gain). My LBS told me that Shimano is not selling chainrings only (you have to get the whole crank set). My only option would be third party chainrings. I could get SRAM Red ETap chainrings with the power meter or another third party option.
My questions are:
Are the SRAM Red ETap chainrings compatible with the Shimano 9150 Di2 drivetrain (shifters/derailleurs/cassette)?
If so, what chain would I use?
If not, what chainrings would you recommend?
Thanks for your help,
Brian
PostPosted: Sat Jul 08, 2017 1:23 am
I have the Quarq Red 22 cranks with Red chainrings, 50/34. Running DA 9070, Sram 1190 cassette, and DA 11-speed chains. Everything is running perfectly. I have never used the 4-arm DA chainrings. However I feel the Red chainrings are plenty stiff and I don't see any downsides to them. Price and weight wise I think they are way less than DA chainrings. Btw I also have Campy Bora wheels. So I care very little about matching brands.
A while back when 9150 first came out, there were reports of poor shifting while using a Sram 1190 cassette. When the poster put an Ultegra cassette on everything is fine. This makes little sense and I never saw an explanation for the problem.
I'm using the Sram 1190 11-28 cassette. I much prefer the Sram ratios as it includes a 16th cog. The Shimano DA doesn't and that's a deal breaker for me.
PostPosted: Sat Jul 08, 2017 1:52 am
How about Praxis chainrings?
Sent from my SM-G930V using Tapatalk
Time VXRS Ulteam (7.16 kg)
viewtopic.php?f=10&t=120268
PostPosted: Sat Jul 08, 2017 4:53 am
Generally speaking, the lighter the rings the less stiff they will be, which will detrimentally affect shifting performance. Forging will make a chainring stronger but not stiffer. The key is to find the right balance between weight and stiffness. When shopping for a chainring I'd look at the weight to judge how stiff it'll be. Shimano has the patent on hollow rings so from a stiffness standpoint nothing will beat it.
There are no new unread posts for this topic. 9150 Di2 upgrade - compatibility with previous gen parts
ParisCarbon
Sun May 14, 2017 5:01 pm
kode54 View the latest post
There are no new unread posts for this topic. Attachment(s) Shimano Compatibility
Valbrona
Mon Jan 02, 2017 10:55 pm
ooo View the latest post
There are no new unread posts for this topic. Shimano ST-R785 Compatibility EW-RS910 Junction Box
gazzaputt
Tue Sep 12, 2017 9:17 pm
gazzaputt View the latest post
There are no new unread posts for this topic. SRAM Red Chainring confusion
TimW
11
755
Mon Jul 24, 2017 5:35 pm
pdlpsher1 View the latest post
There are no new unread posts for this topic. Sram Red 22 crankset and chainring 38T
Shmitt
Mon Oct 31, 2016 8:13 pm
Shmitt View the latest post
Users browsing this forum: Bing [Bot], Drpoomanchu, goodboyr, Google Adsense [Bot], jcjordan, JeffK and 43 guests
