Bike size help 5'10'' height 33.5''inseam
antonio07
by antonio07
I'm 5'10'' - 1.78 meters height and have a inseam of 33.5inches 85.5cm
I'm looking at a Scott Foil 2017, Tarmac
I'm in doubt if I should use 54 M or 56 Large
I tried the Tarmac 54 and really the seat tube is almost at the limit, very high aggressive position.
Some people say 54 other 56 and I never know.
thank for the help.
RyanH
by RyanH
What's your preferred stack height, reach, how much drop do you like to run and what's your saddle height? I was riding a small Foil and your inseam is about 4cm longer than mine at nearly the same height. I wasn't near the max seatpost height on the Foil, but I can't recall how much I had left.
Strava
antonio07
by antonio07
RyanH wrote:What's your preferred stack height, reach, how much drop do you like to run and what's your saddle height? I was riding a small Foil and your inseam is about 4cm longer than mine at nearly the same height. I wasn't near the max seatpost height on the Foil, but I can't recall how much I had left.
Thanks alot for the response.
I ride with 77cm saddle height.
I don't slam the bars down, I pretty much use one or two spacers.
So you are almost the same height as me ?? Shorter legs ? I know I have long legs, unfortunately.
wheelsONfire
by wheelsONfire
antonio07 wrote:I'm 5'10'' - 1.78 meters height and have a inseam of 33.5inches 85.5cm
thank for the help.
I wouldn't go for any of those if i were you.
This based on your prefered saddle height and what i guess would be suitable stack and reach for you.
I would instead look for a frame that is perhaps more suited in size, as prio one.
So with that, i ask you to look at Eddy Merckx 2017 model EM-525.
Before they only had the very long and low performance geometry.
Now they also have endurance geometry.
Check EM-525, medium size.
It's available both with caliper (rim) brakes and disc brakes.
http://www.eddymerckx.com/products/road ... lver-satin
Stack is 576mm and reach 380mm. That could suit you well.
Both Tarmac and Foil or Addict in size 56, is very long and low.
The 54 sized versions are very low.
I had Foil size 56 and changed to 54. But it was way to low for me.
Reach however, were better. Eddy Merckx EM-525 size medium in endurance would be much better with such body proportions
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
RyanH
by RyanH
You'll need to give us some more details about your current fit. What bike are you currently riding, how many spacers, stem angle and length? The seat tubes are short on the Foil but the stack is high.
Strava
antonio07
by antonio07
RyanH wrote:You'll need to give us some more details about your current fit. What bike are you currently riding, how many spacers, stem angle and length? The seat tubes are short on the Foil but the stack is high.
I'm riding a Scott Addict 2015. size 56
The bike fit person put a 90mm stem, 6 degrees stem but not going up it is used straight, 2.5 cm spacers used.
From the floor measured all the way to the middle of the handlebar is 91cm.
I think it is 64-65cm from the bb up to the center of the bars.
Are these info good ? thanks
RyanH
by RyanH
Given that fit information, I agree with wheelsONfire. You're better off looking for a frame that offers endurance geometry as it will put the stack and reach where you need it. The 2015 Addict has 568mm of stack and 394mm of reach. 90mm stem is not ideal, nor is 2.5cm of spacers. A size 56 Roubaix would give you the ability to run a 100cm stem slammed with room to go lower if you got a -10* or -17*.
Strava
wheelsONfire
by wheelsONfire
You could use a stem 14.5mm longer on the Eddy Merckx EM 525 endurance.
Or check what stem size, 100 or 110mm you prefer with chosen handlebar (pending on handlebars reach).
You also have a higher stack at the suggested Merckx, which again would allow you to drop your spacer stack.
It would suit you well from the info you have given.
Bikes:
Open *UP*
antonio07
by antonio07
I understand, thanks
BUT, if I had to choose a SCOTT frame you would say size 54 or 56 ?
Should I stick with the 56 or maybe get a 54 as it has a smaller toptube ??
antonio07
by antonio07
RyanH wrote:Given that fit information, I agree with wheelsONfire. You're better off looking for a frame that offers endurance geometry as it will put the stack and reach where you need it. The 2015 Addict has 568mm of stack and 394mm of reach. 90mm stem is not ideal, nor is 2.5cm of spacers. A size 56 Roubaix would give you the ability to run a 100cm stem slammed with room to go lower if you got a -10* or -17*.
I'm thinking if I buy a 54 I'll keep many spacers to make the bars higher but at least the toptube lenght wouldn't be bad.
antonio07
by antonio07
[quote]
Reach however, were better. [quote]
It was low but did you use the spacers. I don't mind using them to put the bars higher.
How tall are you ? Inseam ??
thanks
antonio07
by antonio07
thank for the help.
thanks
RyanH
by RyanH
Sometimes you have to accept that not every frame is made for you. Given your information though, I'd say get a 56 since a 54 would require 4.5cm of spacers which would probably be getting to the point it's unsafe or detrimental to steering feel. But again, handling is going to be compromised, the bike is not made for you.
Strava
antonio07
by antonio07
Ok man thanks alot !!
Enviado do meu iPhone usando Tapatalk
bilwit
by bilwit
RyanH wrote:Sometimes you have to accept that not every frame is made for you. Given your information though, I'd say get a 56 since a 54 would require 4.5cm of spacers which would probably be getting to the point it's unsafe or detrimental to steering feel. But again, handling is going to be compromised, the bike is not made for you.
Eh, if he's deadset on the frame then he just needs to deal/adjust to a more aggressive position is all, nothing wrong with that.
