It is currently Thu Oct 19, 2017 2:01 pm
PostPosted: Tue Jun 27, 2017 12:40 am
Hi all,
Does any one have experience with crank based power meters and the 2016 Scott Foil. I have a 2016 Scott Foil and I want to get a crank based power meter for it. I do not want pedals(speedplay FTW), and I dont like the restriction that a rear hub has. As you may know the rear brake causes interference which make stages not an option. Also I attempted to install the FSA Power box but the bike would not take the 386 evo BB as the cable guide caused interference with the spindle. I have the bb72-41 and it seems as that is the only bb that fits.
what options are out there?
will the new Shimano fc-R9100-P work?
what PM is on your Scott Foil?
PostPosted: Tue Jun 27, 2017 12:47 am
Power2Max Type S Rotor 3D would work?
PostPosted: Tue Jun 27, 2017 4:56 am
Yes that's one option. I would go for the new Easton ec90sl crank +cinch power meterImage
Sent from my Pixel XL using Tapatalk
20% cyclist/80% J.I.T
PostPosted: Tue Jun 27, 2017 4:58 am
I would not recommend the new Easton EC90SL. Its single sided and you need to use shitty 4130 bearings.
PostPosted: Tue Jun 27, 2017 5:08 am
Beautiful bike. Worth saying again! And again.
How long have you been running the "suspect" 4130 bearings? I've read the same negative, but it appears you're an actual user...
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Tue Jun 27, 2017 5:09 am
Power2Max, Rotor Inpower, 4iii, Pioneer, SRM (€€€€) or Quarq.
Most "innovations" in cycling are solutions for non-existing problems.
PostPosted: Tue Jun 27, 2017 5:27 am
Shimano based Pioneer or SRM would go straight into your current bottom bracket.
A GXP press fit bottom bracket would fit into your frame and take a Quarq nicely.
They'd be the most native options I believe.
Avoid anything that has a pod hanging off the non-drive arm.
Avoid anything with a 30mm spindle.
Grover's Grumblings
Grover's Garage
PostPosted: Tue Jun 27, 2017 5:33 am
Online
FC-9100-P will work with direct mount brakes.
PostPosted: Tue Jun 27, 2017 12:45 pm
I haven't put a ton of km on the bike but I'm running a kogel ceramic bb. It's buttery smooth and with the cross seals I expect it to stay that way. Also the 2 year warranty helps alleviate any fears of the 4130 bearing
Also, this is ww after all. While it's only single leg power, the crankset weighs less with power than a bone stock fc-9000
PostPosted: Tue Jun 27, 2017 2:44 pm
Have you a real weight of yours? Because, if I do the math's, 590 (ec90sl) + 65 (extra weight for Cinch) is more than a stock 9000 crankset, weighting a verified 630gr. But on par with a DA + Stages, and maybe more reliable. I haven't had any issues in almost 20.000 with mine (2th gen), and used in winter also, but there are lots of horror stories over here as well.
Canyon Ultimate CF SLX 2013
Scott Addict Orica Greenedge
Canyon Endurace CF SLX
There are no new unread posts for this topic. Power meter for 2016 Sram red 22
Monkeychunki
Mon May 22, 2017 8:23 pm
ergott View the latest post
There are no new unread posts for this topic. Power Meter options for Canyon Endurance
cockera
Wed Jul 12, 2017 9:33 pm
Ginsterdrz View the latest post
There are no new unread posts for this topic. Which is more accurate, generally, smart trainers or crank based power meters?
Shrike
15
1152
Mon Mar 27, 2017 12:38 am
HakeemT View the latest post
There are no new unread posts for this topic. Lil help w/ old SRAM (Red?) power meter?
Kidtreo
Fri Aug 18, 2017 4:34 pm
sungod View the latest post
There are no new unread posts for this topic. Shimano Power Meter
cunn1n9
Thu Aug 03, 2017 10:48 pm
cycleboyco View the latest post
Users browsing this forum: Bing [Bot], brmf, Chris3g, Google [Bot], lovinmylab, Miller, TurboKoo, Yahoo [Bot] and 34 guests
