It is currently Fri Dec 15, 2017 12:05 am
Post new topic  Reply to topic  [ 231 posts ]  Go to page Previous 19 10 11 12 1316 Next
PostPosted: Fri Sep 22, 2017 8:11 am
Online
They’re not running 1x12.
PostPosted: Fri Sep 22, 2017 8:19 am
tanhalt wrote:
SuperDave wrote:
Marin wrote:
That's pretty cool actually.
If they made the Strada with rim brakes and 3mm more clearance I'd consider buying one :D
What brake calipers would you use for those 33mm tires?
-SD
It's not like medium and standard reach calipers have never existed, right? :wink:
The Strada has an effective tire clearance of 28mm. The Conti 28mm (which are 30mm tires in reality) were heavily rubbing the frames at the launch event. So, 3mm additional tire clearance would make the bike fit for 31mm tires. Those can be cleared by standard direct mount rim brakes. :wink:
thumper88 wrote:
itsacarr wrote:
https://www.aquabluesport.com/blog/aqua-blue-sport-team-up-with-3t-for-2018.html
This should be interesting.
Yeah, I had the same question the writer was left with, going to be interesting what ring sizes they pick. No doubt it will change a lot to suit terrain...
They'll be on a 44 most of the time combined with the new 3T bailout 9-32 cassette. This is pretty much exactly the same gear range as 53-39/11-28.
PostPosted: Fri Sep 22, 2017 8:30 am
It'll be interesting when they need a rear spare - when they're getting an 11-28 they'll run out of gears on the first slight downhill.
PostPosted: Fri Sep 22, 2017 1:04 pm
I've just tried to push a gear at long 10% accent with 70 rpm cadence without usage of FD. I can not imagine how to quickly shift up/down rear derailleur by 2-3 cogs for in/out saddle position each minute of a climbing
PostPosted: Fri Sep 22, 2017 1:43 pm
They might not be running 1x12 today, because SRAM doesn't have a road 1x12...yet. Seems like a logical way to introduce 1x12 to the road.
Unless you have some inside information that by next season they will still be on 1x11.
PostPosted: Fri Sep 22, 2017 2:06 pm
SRAM has already published the specs for their XRD freehub designed specifically for *road* 12x: http://www.xddriverbody.com/90-2415-189 ... LEASED.pdf
From here: http://www.xddriverbody.com/apply.php
MTB 12x is already possible on standard XD
PostPosted: Fri Sep 22, 2017 2:14 pm
Just as an inside to folks regarding the neutral support issue - it's not really an issue at x.1 \ protour events as they will always have 2 support cars + roving soigneurs. Beyond that, neutral support cars historically spend more time giving out water bottles to d2\protour teams than wheels.
I love my tradition as much as the next, but again I'm just happy to see something unique in regards to development in the industry. At this point I guess we will just have to wait and see where it goes.
Just ride ..
http://1k2go.bigcartel.com
https://www.instagram.com/itsacarr
https://www.strava.com/athletes/1044522
PostPosted: Mon Sep 25, 2017 4:19 pm
-SD
Yes, I used them for the Paris-Roubaix specific frames developed for World Tour teams in my previous life. Having had the joys of working with such oddities as non-series Tiagra level non-inventoried items I'll stick with the disc brake route.
-SD
http://www.3Tcycling.com
https://www.strava.com/athletes/164090
PostPosted: Mon Sep 25, 2017 4:27 pm
SuperDave wrote:
-SD
-SD
But, using "non-standard" cassettes and freehub bodies doesn't bother you? Seems inconsistent :wink:
PostPosted: Mon Sep 25, 2017 4:37 pm
tanhalt wrote:
SuperDave wrote:
tanhalt wrote:
-SD
-SD
It does bother me. I don't use the 9-32t personally. After spending a couple months on the bike the team riders, testers and nay-sayers requested some options for 1x that simply were not commercially available in a cassette so we saw an opportunity to produce them. The two 9-32t 11 speed options we make will eventually be outdated as 1 x 12t comes to the performance road market and along with it an abundant range of options for cassettes. Today there is really only 10-50T from SRAM and 9-48t from an obscure aftermarket brand. Those two options are not ideal for road use. Once 12 speed cassettes are made with the options consumers need we won't need the 11 speed Overdrive and Bailout 9-32t option.
I'm personally happy with an 11-40t with a 52t up front for the roads I spend most of my time on. For flat race days I swap an 11-25t on the wheel. For BWR I'll likely change to an 11-46t out back. The production STRADA will be outfitted with a 50t up front and 11-36t in the back (biggest gear is bigger than 54T x 12t, smallest gear is smaller than 39T x 28t) which should be adequate for much of the consumer base looking for a 1x road bike.
PostPosted: Tue Sep 26, 2017 7:53 am
WTF? 3T doesn't trust their own product?
PostPosted: Tue Sep 26, 2017 5:45 pm
I'm not sure why you'd draw that conclusion other than to be adversarial. The production of the bike kit is ahead of the production of the cassette by several months. Cooperation from SRAM during the development phase of a frame ~1 year ago required the selection of a complete Force 1x group. Requesting the purchase of SRAM parts for OEM production of a bicycle that didn't exist outside of the 3T knowledge base presented some challenges. For the last ~20 years 3T and SRAM's Zipp component brand have been competitors, now we're entering a new relationship. The cassettes will be used by the AquaBlue Sports team (when needed) and will be available to consumers in November.
Not sure if your question was rhetorical but there's ^^^ an incredibly condensed reply. If you'd like more information on the timelines for such an endeavor, the sourcing protocol for SRAM, the MOQ in terms of dollars required to enter into a OE relationship, the various revisions to our own cassette design and decision to offer two different 9-32t ranges and other contributing factors to the staggered release of the frame, the one complete parts kit option, and our cassette please let me know.
-SD
PostPosted: Tue Sep 26, 2017 6:54 pm
Thanks for the detailed reply Dave, I'd actually love to learn more.
Btw I'm getting the Bailout cassette the moment it's available (if I can afford it) because it's just what I need for my multiple 1x bikes.
PostPosted: Tue Sep 26, 2017 8:10 pm
Ok.
When we began development of a component/kit option for our frames imagine a 3T employee asking a SRAM employee for a price list. How do you think SRAM would react in March 2016 to this request from 3T? A SRAM OE price list contains a wealth of confidential information including costing on handlebars, stems, seatposts, wheels and other parts that 3T also manufactures. It may also contain country of origin, bulk packaging quantities and other details that would allow 3T to position our products at a competitive advantage in an OE marketplace. 3T was not in a position to expose our intention of launching a frameset yet we needed SRAM parts to outfit the bikes. This is just one of the hurdles to initiating the acquisition of components be it SRAM or Shimano. Now today our intentions are clear to SRAM that we outfit our frames with their parts but if we sourced a component groupset without a cassette surely the question would be raised, "who's cassette are you using" and thus some dialogue would need to begin on 3T creating a competing product in the drivetrain category. So we continue to cooperate by buying complete groups from SRAM so they are ready for our frame launch. The lead time for frame production hovers around 120-150 days from PO to delivery and components are 90-120d. When the frame was ready for production we had just 30 days to finish the cassette design that was largely based on feedback from riding the frame! So you can understand that in order to be prepared for sales' needs we had to outfit the complete bicycle option with parts that were available 120 days ago. So we did that. It is also worth noting that in many areas of the planet the 9-32t is far more range (356%) than is required. In Florida, the Midwest, Texas, Dubai, Netherlands, etc riders have been using 1x on their performance bikes with 11-25,6,8, and 32t cassettes. Here the 227-290% range is adequate so the production bike can be set up and/or catered to a broad audience by keeping the 50T ring up front.
Ok, that's lesson 1. Come back later for 2 thru 50
-SD
PostPosted: Wed Sep 27, 2017 2:03 am
Where is the upvote / like / +1 button? This is great, SD.
Any hints on firmware update on existing eTap WiFLi RD so that it could support 12-speed XDR cassette? like 10-36...
I really wish there will be 10-11-12-13-14- 16-18 -21-24-28-32-36
There are no new unread posts for this topic. Rotate saddle on aero road bike?
mrsparkle
Tue Oct 10, 2017 6:35 pm
BeeSeeBee View the latest post
There are no new unread posts for this topic. Want new disc aero <15lbs road bike... confused
[ Go to page: 1 2 3 4 ]
unlucky
47
5474
Fri Oct 06, 2017 8:14 pm
Renne View the latest post
There are no new unread posts for this topic. Wide clearance road forks
thedonnydino
Sun Jul 30, 2017 2:10 am
mpulsiv View the latest post
There are no new unread posts for this topic. Alloy road bar with a drop curve like the ENVE SES Aero Road Bar?
VTR1000SP2
11
1675
Wed Oct 04, 2017 4:08 pm
cwdzoot View the latest post
There are no new unread posts for this topic. Aero bars on non aero race bike
gurk700
18
3743
Wed Dec 13, 2017 7:07 pm
TonyM View the latest post
Users browsing this forum: Bing [Bot], coachboyd, Dowks, raggi, sooni, Ticlimax, TobinHatesYou, wingguy and 28 guests
