2017 Cannondale SuperSix Evo Hi-Mod with Di2
alastairb
by alastairb
I've just had one of these built up and am looking for something to fill the holes around the bottom bracket where the cable guides no longer are..the retailer tells me Cannondale don't offer anything that does this!
Has anybody bought a complete SuperSix with Di2? What does that come with?
Picture attached of the area I'm talking about.
Any help greatly appreciated.Image
Sent from my SM-G935F using Tapatalk
Delorre
by Delorre
Put some 3M car paint protecion tape (or helicopter tape) on it. Just leave the drain hole, otherwise, you BB will be drawning!
asiantrick
by asiantrick
I use 3M clear tape for mine.
Ravnsnaes
by Ravnsnaes
My 2017 Evo Hi-Mod Di2 Disc has some rubber plugs, where the mechanical cable guides used to be. And I've seen them on the Sram eTap rim brake model as well. Don't know if these are available seperately.
alastairb
by alastairb
Thanks all, looks like I"m trying to source some rubber plugs...
jeffy
by jeffy
look up sugru. mould your own plugs.
alastairb
by alastairb
jeffy wrote:look up sugru. mould your own plugs.
Will do; thanks.
nismosr
by nismosr
can you measure the hole .. i may able to get you a plastic plug at work.
jlok
by jlok
Park Tool GP2 Tire Patch is cheap and easy to apply...
alastairb
by alastairb
nismosr wrote:can you measure the hole .. i may able to get you a plastic plug at work.
Thanks for this; think it's resolved biut appreciate your offer.
djwalker
by djwalker
My SuperSix Himod came with the holes open and I have left them that way. No problems yet after 9 months. I think that they act as drain holes for any water that gets into the BB via the seat tube or whatever. I had one bike that had a sealed BB shell and ended up with about 1/4" of water inside of it after riding in the rain and water getting in from somewhere. So, I added a drain hole and the problem went away. All the bearings are sealed on the inside as well as the outside.
1415chris
by 1415chris
Would you cover your driveway drainage? ;)
