It is currently Wed Oct 18, 2017 10:14 am
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Tue Jun 13, 2017 8:07 am
My white 2012 Hi-Mod had 29mm clearance at the tire, so 25mm was already tight if you wanted some safety clearance for an untrue wheel etc.
That was the only reason I sold it. :(
The follow up Orbea Orca OMR has 40mm clearance at the tire, so real 32mm wide tires would be possible... Limiting factor is the brake bridge, that's a maximum of 28mm - so a 28mm tire on a 21C rim will be the widest it will take.
Infos on wide tires, rims and aerodynamics
PostPosted: Wed Jun 14, 2017 1:18 pm
Not sure where all the tire/ wheel clearance issues and questions are coming from. I have a 2015 High-Mod and a set of Enve 6.7's (24 mm wide rear and 26mm wide front) and am running Vittoria's new Corsa G+ tires in 28mm and have had no issues. I have seen nothing on the rear (scratches, rubbing, ext.) If anything the only thing I have noticed is some scratching on the top of the front fork but it has been superficial at most.
PostPosted: Wed Jun 14, 2017 1:20 pm
I have a 2015 super six evo( non hi-mod) aswel. cant ride with wider rims and 25mm tyre in the rear.
PostPosted: Wed Jun 14, 2017 4:10 pm
I believe frame size is an important metric. As you go up and down frame sizes, clearance increases and reduces (very slightly) accordingly. That was my experience with my old HiMod, anyways.
PostPosted: Wed Jun 14, 2017 7:16 pm
The 1st gen. is tight, even in 56/58cm:
The 2nd gen. is better:
PostPosted: Wed Jun 14, 2017 7:42 pm
I have a 2014 HiMod (size 54) and have run (or tried to run) the following combos:
DA 9000 C24 clinchers
w/25mm veloflex corsas - no problem
w/27mm challenge paris roubaix open tubular - no go. stuck on rear chainstay
Zipp 303 firecresst clincher (28.5mm wide, 26.4mm at brake track)
w/25mm veloflex corsa - tight but works. No noticeable rubbing (and I'm 180lbs)
Easton EC90 Aero55 Tubular (30mm wide, 28mm at brake track)
w/25mm vittoria corsa cx - tight at front (sram red caliper) but works. No go at rear, gets stuck on chainstay
w/22mm continental sprinter - VERY tight at rear chainstay. Rubs a bit under sprinting/climbing out of the saddle. Wheel must be perfectly true and used with provided Easton QR (heavy and stiff - even dura ace QR no good).
Honestly I'm thinking I have to get rid of the Aero55 tubs. I threw the wheel out of true recently and rubbed all the way home. I think I have to accept they are too wide for the frame (or the frame + my weight). Its a shame cause I love the wheels.
PostPosted: Wed Jun 14, 2017 9:46 pm
2012 56cm Evo w/ C50 & Veloflex Arenberg:
@ 2.5mm NDS:
@ 3mm DS:
PostPosted: Wed Jun 21, 2017 2:31 pm
I am a little confused on all of the fit issues, I have a 2013 Cannondale Super Six Race Edition Hi mod that I just fitted GP2000 II's 25mm size. Now I have not rode it yet but it appears that I have plenty of room for the tires with no chance of rubbing anywhere.
frame is a 52CM
Enve 3.4 wheel set
27.2 seat post size
Not sure why people have all the fit issues unless I am just missing something here. Wouldn't all the bikes from a particular year model be the same?
PostPosted: Wed Jun 21, 2017 5:42 pm
In theory, yes. Who knows if Cannondale had more than one supplier of these frames or or or... . I do know that early SSEvo's were pretty well known for having dropout alignment issues that would result in an off center wheel, so I don't think the qc in the early years at least was spot on. As I said, my 2012 52 has room for tires that measure 28 actual. So I dunno.
PostPosted: Wed Jun 21, 2017 5:47 pm
My 2013 had 1mm of clearance with 27.5mm actual. While that technically clears it's too close to be usable.
Strava
Current Stable. The Snob Machine | The Crumpton
The Ex's. LS Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | LS Xicon: 5.76kg | C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg | Evo - 5.18kg | LS Classic - 6.7kg
PostPosted: Thu Jun 22, 2017 5:16 am
2013 hi mod, 52cm, black gloss paint.
32mm between the chainstays at the tire sidewall's widest point
Present wheelset is HED Belgium C2, present tire is Specialized 24mm. Measures 25mm
Rims are about worn through, so I have Belgium Plus rims on the way.
Fingers crossed, will know soon what fits.
PostPosted: Thu Jun 22, 2017 9:09 pm
2014 Super six evo hi mod with Mavic pro carbon slc wheels and GP2000iis 25mm no clearance issues also no clearance issues with the Mavic griplink and powerlink 25mm tires either.
PostPosted: Fri Jun 23, 2017 3:52 pm
I know this will depend on your wheel set but what is everyone's opinion on what the min. clearance (mm) it should be from tire to chain stays?
PostPosted: Fri Jun 23, 2017 8:30 pm
I think that's a good question and yes, some wheelsets will be more likely to flex and rub. I ran it for a ride with 1mm of clearance on each side and didn't get rub with the Enve 4.5s but I wasn't keen on doing that long term. I think 2mm each side should be good.
Strava
PostPosted: Fri Jun 23, 2017 11:32 pm
I just fitted my bike with 25mm tires, I have 3mm clearance on both the drive side and non drive side. Is that going to be enough or should I go back to 23mm?
There are no new unread posts for this topic. Attachment(s) Pinarello DOGMA F8 + HED Stinger 4 clearance issues
xmashx
11
1131
Wed Mar 22, 2017 2:57 pm
xmashx View the latest post
There are no new unread posts for this topic. Cannondale EVO 2nd Gen. Rim Clearance
Beaver
Sun Mar 05, 2017 10:30 am
Beaver View the latest post
There are no new unread posts for this topic. mudguard no clearance
Timmy269
7
396
Sat Aug 12, 2017 4:02 pm
11.4 View the latest post
There are no new unread posts for this topic. 3T Funda Tire Clearance
nvroadie
Sun Mar 26, 2017 4:02 am
EightySixer View the latest post
There are no new unread posts for this topic. Pinarello F10: tire clearance?
TonyM
Tue Oct 17, 2017 1:50 pm
fogman View the latest post
Users browsing this forum: Baidu [Spider], Google [Bot], Lewn777, Rexenes and 41 guests
