Super six evo hi mod clearance issues
toastie
by toastie
I currently have a 2015 super six evo hi mod and was looking for some new wheels, something along the line of a set of zipp 202 or 303 but am concerned about the rim width which is 25.4mm. I currently run with dura ace c24 wheels running 23mm tyres, I tried to swap to 25mm tyres but there's not enough frame clearance. I was wondering if anyone runs a 25mm rim with 23mm tyres and knows if it will clear this frame.
Jepas
by Jepas
303 firecrest with 23mm tyres on a 2016 SuperSix without any problem.
glepore
by glepore
AL33's, which are as wide and wider internally, with tires that measure an actual 28 (vittoria corsa 25's) no issue.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
toastie
by toastie
Thanks for that. Maybe tubs don't change shape/size as much as clinchers do when you put them on different size rims
Lieblingsleguan
by Lieblingsleguan
Jepas wrote:
toastie wrote:I currently have a 2015 super six evo hi mod and was looking for some new wheels, something along the line of a set of zipp 202 or 303 but am concerned about the rim width which is 25.4mm. I currently run with dura ace c24 wheels running 23mm tyres, I tried to swap to 25mm tyres but there's not enough frame clearance. I was wondering if anyone runs a 25mm rim with 23mm tyres and knows if it will clear this frame.
2016 SuperSix HiMod has loads more clearance than 2015.
toastie
by toastie
Oh ok thanks for that. So anyone on a pre 2016 running 25mm wheels on their bike
asv
by asv
toastie wrote:Oh ok thanks for that. So anyone on a pre 2016 running 25mm wheels on their bike
Yeah 2013 Evo Himod here, running pacenti SL23 with Vittoria Pave 25's. When I run my enve 3.4's I use 23 Corsas.
Lieblingsleguan
by Lieblingsleguan
Yes, you want info from people who run a SuperSix Evo or SuperSix Evo HiMod with 27,2mm seat post diameter. The old SuperSix (the non-Evo) had more clearance and allows for 28mm tires. The new SuperSix Evo with 25,4mm seat post diameter also has clearance for 28mm tires.
I myself have a 2015 SuperSix Evo (non HiMod). There is not much clearance at all. I am running 23mm Vittoria Corsa G+ which measure exactly 25mm wide on 15C wheels. There are about 2mm of clearance between tire and chainstay on each side.
A friend of mine runs DT Swiss R460 rims with 23mm external width at the brake tracks and this is about as wide as I would go. A rim that is wider near the spoke nipples might be ok, but I haven't tried it (and I won't). I'm a big guy, so I will go for a new frameset if I find one for a good price.
glepore
by glepore
glepore wrote:AL33's, which are as wide and wider internally, with tires that measure an actual 28 (vittoria corsa 25's) no issue.
Quoting my own post- to add mine is a 2012.
toastie
by toastie
I wonder if they're is some variation in frames as no way could I get a tyre measuring 28 in my frame. My 23mm schwalbe come up at 25mm on the dura ace rims and I definitely wouldn't want to chance much wider than that in there
Svetty
by Svetty
Yes, as per posting elsewhere ;)
sovereign
by sovereign
2012 Evo Himod
25c Schwalbe One Tubeless on DA C24 (measured tire width 26mm)
25c Veloflex Arenberg on DA C50 (24mm width rim, tire measures 25mm)
Both fit.
JoeFlan
by JoeFlan
I have a 2013 super six evo I've tried fitting HED Belgium Plus rims (25mm rim outer) but they do not fit at all. Currently, I am having some good luck running Hed Belgium C2s (23mm rim outer) with 23mm Vittoria open corsa cx that measure 25mm.
Current Steed
Supersix Evo 6.25kg
Giant TCR SLR 6.8kg
Past Lovers
Focus Izalco Pro
Cervelo S1
Bigger Gear
by Bigger Gear
One of my best friends rides a 2016 Super Six Evo Hi Mod and he was trying to run GP4000S II in 700x28 on Mavic Ksyriums with an internal width of 17C. They fit, but just barely, and IMO the rear clearance was too tight. Actually the worst clearance point was on the rear DA9000 brake caliper, anything picked up on the tire was going to hit the brake first. Lateral clearance at the stays was also very tight, too tight for my own comfort. After a few hundred km he has since gone back to 700x25.
Chemmy
by Chemmy
2015 Supersix Evo, non-himod, I'm running Pacenti SL23s with 25mm Conti GP4KSIIs. They measure out at exactly 28mm inflated.
They fit, but it's real close.
