Investing in BB30 PM a bad idea?
dudemanppl
by dudemanppl
Nope, long spindle.
jlok
by jlok
It's BB386.
bm0p700f
by bm0p700f
does the OP change his/her bike every year if so you can afford a new PM. as for an investment all bike kit is poor as none of it appriecates in value.
Since BB386 solves this problem the question is moot anyhow.
SixThirteen
by SixThirteen
You could try Team Zwatt Zspider - L/R power, native BB386 and they can supply adapters for many BBs. For example can go into both my S2 (BBRight) and CAAD9 (BB30)
https://shop.teamzwatt.com/product/team ... wer-meter/
AW84
by AW84
bm0p700f wrote:does the OP change his/her bike every year if so you can afford a new PM. as for an investment all bike kit is poor as none of it appriecates in value.
Definitely not. Every 5-6 years, maybe.
srshaw
by srshaw
Daniel1975 wrote:
dudemanppl wrote:Buy BB30, that will fit any BB except Trek BB90.
First one the pops up in my head: no Pinarello will ever fit with a BB30 crank!
Nor any new Cannondale with bb30a or Cervelo with bbright. In fact only bikes that could be used with bb30 are bb30 or pf30 bikes.
dudemanppl
by dudemanppl
Oh my god LOL we just outlined this. A BB30 Quarq fits in everything that isn't BB90. In fact it will still fit BB90. So yeah it fits everything.
AW84
by AW84
What frames out there are BB386? Still seems pretty limited with it only compatible with two frame/bottom bracket standards.
AW84
by AW84
dudemanppl wrote:Oh my god LOL we just outlined this. A BB30 Quarq fits in everything that isn't BB90. In fact it will still fit BB90. So yeah it fits everything.
Without buying new arms/spindle, how does it fit everything but BB90?
jlok
by jlok
Quarq made the really bad decision to call their carbon DZero as bb30. It's actually bb386.
With the right bearings/BB it's technically compatible with frames using bb86/bb30/bb30a/bright/bb386 sans bb90 (or does it?).
AW84
by AW84
jlok wrote:Quarq made the really bad decision to call their carbon DZero as bb30. It's actually bb386.
I've confirmed with SRAM and Specialized that it's directly compatible without any adapters. Are you saying that is incorrect?
jlok
by jlok
You mean BB90? should be ok with 4130 bearings.
AW84
by AW84
No, directly compatible with an OSBB Tarmac.
dudemanppl
by dudemanppl
https://www.lightningbikes.com/cranks/b ... -cups.html
For Trek. Scroll down to BB90/95. 4130 bearings wouldn't fit.
AW84, please find all the correct information before you make another post. Don't spread the wrong info.
Calnago
by Calnago
Investing in BB30 was a bad idea when Cannondale came up with it and it's a bad idea now. If you haven't yet invested in a crank based powermeter then don't go with a 30mm spindle option. At the time BB30 came out, 30mm spindles were touted as being lighter, and stiffer. They were made of aluminum. They had to make them bigger to get the stiffness. Trouble is, aluminum is quite susceptible to thermal expansion and contractions. So, throw an aluminum spindle into some steel bearings and you have what's affectionately known as Creakendale. Then, trying to keep the bearings themselves from moving in an often imperfectly round BB shell can be a challenge as well. Retaining compounds can help, and in fact I have had pretty much complete success with using them, but it is a little hard to press in the bearings without squishing some of the retaining compound into the bearings or out the other side against the retaining clip which... squishes the compound into the bearings. So... as possible solutions were pondered, they came up with PF30, which still uses a 30mm spindle but the bearings are encased in delrin cups, which are more tolerant of the imperfections of the BB shell. Still, you usually have to use a retaining compound and primer, but at least it's a relatively easy operation. There are enough adapters out there that you can convert your PF30 shells to use a ~24mm based steel spindle power meter which is much more transferrable to various BB's out there. And the steel spindles are not susceptible to the temperature contraction/expansion that aluminum alloy spindles are. I'm sure you've heard of people freezing their Cannondale spindles to make it easier to install them in the bearings. The whole BB30/PF30 fiasco has spawned an entire cottage industry of companies with their own "solutions" to the problem that didn't exist prior to BB30/PF30. Some are better than others, and many work very well. But if I was buying a crank based powermeter for the first time, I'd get something with a "standard" (meaning not 30mm) spindle and avoid having to use teensy bearings in BB's that aren't large enough for normal size bearings just to accommodate a 30mm spindle.
