Shimano quicklink
Buddysnack
by Buddysnack
I've been reusing a Sram quick link on Dura Ace 11 speed chains for several chains. I've had no problem whatsoever...but should I be concerned? I still have to use a tool to take it apart. I've been using it to clean my chain.
Sent from my SM-G900W8 using Tapatalk
F45
by F45
I've used the SRAM ones on Shimano chains ever since someone had a sale on them for like $1.29 each. Got 20 of them. No reason to change to Shimano.
commendatore
by commendatore
I reinstall the sram links on xx1 chains... but every time I think about it I get a little nervous.
pdlpsher1
by pdlpsher1
F45 wrote:I've used the SRAM ones on Shimano chains ever since someone had a sale on them for like $1.29 each. Got 20 of them. No reason to change to Shimano.
I've seen the 10-speed version of the KMC link go that cheap. But all 11-speed versions are at least $5 a piece. Is yours 11-speed?
pdlpsher1
by pdlpsher1
ooo wrote:Shimano SM-CN900-11 vs KMC CL555:
I just bought four pairs from this eBay seller. With shipping from Taiwan it worked out to be $6 a pair. Not too bad considering the KMC version sells for that much here in the U.S.
F45
by F45
pdlpsher1, currently Ribble has the SRAM 11 speed for $2.66 per.
pdlpsher1
by pdlpsher1
F45 wrote:pdlpsher1, currently Ribble has the SRAM 11 speed for $2.66 per.
Thanks. I just need four pairs to get me through my current Dura Ace chain inventory. I called Shimano USA and asked them when will the new link be included in their chains. He said not for 'many months'.
kode54
by kode54
I've used the KMC 11spd quick links with no problems...and with the remove and open tools. i reuse them only if they click back in together with the close tool, than by hand. if they fit by hand easily, that's when i figure i have to replace it.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
slake21
by slake21
anyone installed it yet? I'm struggling with it right now.
the pin is stuck there, and I cant get it through however I try..
I don't have specific pliers but that wasn't a problem with my KMC link
Curious George
by Curious George
slake21 wrote:anyone installed it yet? I'm struggling with it right now.
Easiest way to install is to have it on the top of the chainline, hold left crank at 270d and press down with right crack.... works with all chain QR's
slake21
by slake21
it worked! thank you! :beerchug:
Y26
by Y26
Hi there,
Can you share where to find a deal like that? Is it for 11 speed?
pdlpsher1
by pdlpsher1
Yup. I use the Park link plier and these links are tight! Now to remove the link you will need the plier!!
