Colnago C60 Bottom Bracket Tool
markyboy
by markyboy
I am going to do the quick release as well :thumbup:
COLNAGO C60 SUPER RECORD EPS
Pinarello f8 sram etap
Eddy merckx 69 ultegra disc winter bike
Calnago
by Calnago
markyboy wrote:
thebman wrote:
cloudnine wrote:I believe the tool comes in the box with the frameset, perhaps someone near you that has a V1-r or C60 can loan you one?
Mine did not come with it :(
Mine came with the tool but it does not even fit, i just tried it, not to remove it but just to see if its the right one.
What? The tool for the Threadfit cups does not fit? Got a pic of the tool and the TF cups on your bike?
markyboy
by markyboy
just will not fit,this came in the box from colnago with all the other little bits in.
Willem
by Willem
Calnago wrote:It did come with the frameset at the very beginning of the run but then it became a special order item shortly after I believe.
Just received a new 2017 C60 frame in box, came with the tool in a bag with all the plugs, derailleur cable guide, etc.
I would advise the OP to go to his dealer where he purchased the bike and ask for it.
Good idea to re-install those like you did, on every new frame.
Willem
by Willem
markyboy wrote:just will not fit,this came in the box from colnago with all the other little bits in.
It fits, just use a little persuasion, a plastic mallet with a few light taps.
thebman
by thebman
Calnago wrote:In this thread the OP kind of made it sound like he had checked everything else. Live and learn.
Correct.. I did check the QR previously but only greased the contact point not the hinges. This time greasing the hinges did the trick. Thanks for the Campy QR recommendation, I actually have a set laying around here in the garage.
