It is currently Wed Jan 17, 2018 2:09 pm
Post new topic  Reply to topic  [ 43 posts ]  Go to page 1 2 3 Next
PostPosted: Tue May 30, 2017 5:23 am
Which one is in your opinion easier to get to a light weight?
Seeing as many of these have integrated brakes, seatposts, handlebars, cables, not much can be done to minimize weight.
So in the search for a light aero bike these days, which one stands out?
Plus points if it's award winning aero design :D
/a
PostPosted: Tue May 30, 2017 5:29 am
The least integrate designed has the best potential to get wwed. But that might lose the aero advantages... and I hope the selection of the ww components would beat the original aesthetic.
PostPosted: Tue May 30, 2017 6:12 am
Scott Foil will be one of your lightest options.
I had mine at 6.2kg with the RZRs, eeBrakes and a Red GXP Quarq (760g). I think I could have gotten it down to 5.5kg with some effort.
Subtract 200g for the power meter and add back 250g for Bora 50s to keep the build reasonable. Image
Strava
Current Stable. The Snob Machine | The Crumpton
The Ex's. LS Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | LS Xicon: 5.76kg | C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg | Evo - 5.18kg | LS Classic - 6.7kg
PostPosted: Tue May 30, 2017 4:45 pm
My AR FRD was 6235g without a lot of effort. eTap, EE brakes, and Reynolds tubulars (~1340g). With the same spec that's currently on my C60 - the AR would have been ~5.8kg
And I think it's pretty aero :)
Current:
T2
Retired:
PostPosted: Tue May 30, 2017 5:05 pm
A Felt AR FRD in a size 56 will be significantly lighter than a Foil Team size 52 frame
The current Madone is heavy - there's just no way around it. It has proprietary brakes and bar/stem combo and the seattube w/in a seattube construction (for IsoSpeed).
If you can get your hands on a previous-generation Madone (the one with the BB mounted brakes), you can really get that light, while having good aero properties. To give you an idea, on a 54, my shop weighed an H1 Madone to an H1 Emonda, and found the Madone to be 50g heavier than the Emonda. It takes pretty much any off-the-shelf part, and if you can find a Vapor Coat, you're already ahead of the game.
PostPosted: Tue May 30, 2017 6:00 pm
http://www.tour-magazin.de/raeder/rennr ... 42207.html
Last Tour test - "Gewicht Rahmen/Gabel/Steuerlager" is "weight frame/fork/headset".
Infos on wide tires, rims and aerodynamics
PostPosted: Tue May 30, 2017 6:43 pm
Been working on the missus bike, still pedals, cassette and brakes to do. 200g left to come off.
6.83kg for the time being though.
S5 is heavier, but can go sub 7.
PostPosted: Tue May 30, 2017 6:55 pm
I think you should concern yourself with the components you're putting on the bike.
Tubulars + top of the line groupset will make something "light" automatically.
Let's face it: aerobikes are pigs (I own one). No matter what light components I put in it, it'll always be heavy unless I dig in my pockets deeper.
PostPosted: Tue May 30, 2017 7:07 pm
There is a Garneau Gennix A1 from blacksmith on here that's pretty svelte.
The Scott and FRD are also great options.
Just ride ..
http://1k2go.bigcartel.com
https://www.instagram.com/itsacarr
https://www.strava.com/athletes/1044522
PostPosted: Tue May 30, 2017 9:13 pm
yup. my Parlee ESX is pretty heavy. don't even have to weigh it. plus, i have 25mm tires on it with Enve SES 6.7 clinchers. i could probably throw more money at it, but don't see any reason to...or tune it by cutting the seat post shorter and putting tubulars on it.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Tue May 30, 2017 9:16 pm
I have seen some light F10 builds, sub 15 lbs. Haven't seen any venge vias below 16, but love the bike.
PostPosted: Wed May 31, 2017 1:11 pm
My bet is Trek Madone, leaning on looks and comfort
PostPosted: Wed May 31, 2017 5:40 pm
http://www.neilprydebikes.com/bikes/nazare/
The NazareSL must be very close 920g frame in a L, 180g seat post and 360g Bar/Stem combo. NP are normally pretty accurate to claimed weight and some of the best riding bikes around, they have a really nice feel to them.
J
PostPosted: Wed May 31, 2017 6:40 pm
The cable routing on that Nazare just looks lazy and unattractive.
There are no new unread posts for this topic. Aero test. Trek Madone, Venge, Cervleo S5, Giant Propel & Canyon Aeroad
[ Go to page: 14 5 6 7 8 ]
User Name
105
15822
Wed Sep 20, 2017 5:38 pm
BeeSeeBee View the latest post
There are no new unread posts for this topic. Attachment(s) Venge ViAS aero-clipon bars Di2 remote shifters
warx
Sun Feb 05, 2017 6:02 am
warx View the latest post
There are no new unread posts for this topic. Attachment(s) Madone is the aero king - why?
alcatraz
107
8395
Wed Nov 22, 2017 3:33 pm
mag View the latest post
There are no new unread posts for this topic. Attachment(s) New Venge Vias Disc or stick with my buddy 2015 sworks venge
speedworkx
Mon Jul 10, 2017 7:25 pm
Spez View the latest post
There are no new unread posts for this topic. Lightest aero base bar + stem combo? (separate or integrated)
alcatraz
Fri Aug 18, 2017 10:52 am
Juanmoretime View the latest post
Users browsing this forum: crux, KCookie, MagicShite, MayhemSWE, ride1970, zirxo and 40 guests
cron
