New Easton Ec90 Crankset
ab01ns
by ab01ns
I just ordered the new Easton EC90sl crankset in mid compact double form, 172.5 length. I wanted a light crankset with the option of adding power and that is lighter than a dura ace crank and maybe more cost effective on a $/gram basis. I should get it this week and will update this thread with verified weights for the 2x setup and an overall review of the crank. I can't waitImage
Sent from my Pixel XL using Tapatalk
20% cyclist/80% J.I.T
MichaelB
by MichaelB
So who are the best suppliers for the spiders ?
Presume that the Specialised spider does not fit ?
ab01ns
by ab01ns
I ordered the stock Easton spider. I might have chain line issues cause it's designed for 142OLD bikes but we'll see. I'm running di2 so I can probably sort them out if they do exist.
eric01
by eric01
Let us know how it works out. If I was in the market for a new crank I'd definitely be considering this one. (I have a Rotor 3D+)
IIRC, its based on the same tech used in RaceFace's mountain cranks which has been well reviewed.
AX Lightness Vial Evo, Carl Strong Titanium
Zak
by Zak
I just pulled the trigger on this crank with a single chainring for my roadbike. I have received it and the manufacturer claimed weights were not exagrated. Actually a few grams lighter for the crankset, but I have 170mm crankarms. And the BSA BB was 3-4g lighter than adverticed.
I have mounted the crank and riden it a couple of times and so far so good. My only complain is that there is a 4-5mm preload ring on the inside of the left crankarm which make the transition from crankarm to bb not so elegant.
Zak
by Zak
oh and a little question. The cranks came with small washer where you mount the pedals. Are theese washers nessesarry (my old campy cranks didn't come with any)? My pedals are with ti-spindles if that makes a difference.
ab01ns
by ab01ns
@zak that's awesome to hear. I'm running a kogel bb so that's a step above the race face/Easton version and I love love love the kogel design. As for the preload ring I run a campagnolo comp ultra on my other road bike so I'm no stranger to weird expanding rings on the NDS. I don't know about the washers for the pedals. I like as narrow a q factor as I can get so I avoid washer like that whenever I can. Also, I run ti spindle look keos so we'll see when I get it.
Zak
by Zak
@ab01ns: Thanks for the quick reply. My reason to mention the washers, was that I want to avoid them as I also prefer a narrow q-factor.
I'm not sure you can avoid the preloadring on the inside of the left crankarm as it is a part of the crank and not the BB, but please keep us updated on that when you get your crank.
ab01ns
by ab01ns
Zak wrote:@ab01ns: Thanks for the quick reply. My reason to mention the washers, was that I want to avoid them as I also prefer a narrow q-factor.
What I meant is that I'm totally cool with the look of the preload ring on the NDS
Zak
by Zak
:thumbup:
eric01
by eric01
I googled the instructions. Says "use pedal washer" with a red exclamation mark.
https://www.eastoncycling.com/media/Cin ... lation.pdf
Zak
by Zak
@eric01: Yes I saw that in the instructions when I mounted the cranks and I also used them. But I just wondered why they are nessesary and if they can be avoided.
DamonRinard
by DamonRinard
Pedal washers extend the fatigue life of the crank's alloy threaded insert.
Damon Rinard
Engineering Manager, Road Bikes
Cycling Sports Group, Cannondale
Ex-Kestrel, ex-Velomax, ex-Trek, ex-Cervelo
Mep
by Mep
Zak wrote:@eric01: Yes I saw that in the instructions when I mounted the cranks and I also used them. But I just wondered why they are nessesary and if they can be avoided.
If the pedal spindle is smaller in diameter than the recessed area of the crank arm then I don't think it's necessary. Speaking for Sram cranks but would probably apply more generally as well.
mattyNor
by mattyNor
they make both disc and non-disc spiders, why didn't you just get the right one lol?
