It is currently Tue Oct 17, 2017 4:50 pm
PostPosted: Mon May 29, 2017 3:29 pm
Hey fellas...
So I'm looking for a new frame. I'm happy with BB30. I like the minimalistic approach and I got a lot of bb30 stuff I can use.
So I'm wondering which of the most aero bikes today still support a standard bb30 crank? Aeroad? Foil? Madone?
I know the cervelo s5 is bbright.
Thanks! /a
PostPosted: Mon May 29, 2017 3:45 pm
Felt AR series bikes use BB30
http://www.feltbicycles.com/USA/2016/Bi ... r-frd.aspx
PostPosted: Mon May 29, 2017 3:59 pm
Aeroad yes. Changed the missus' BB on it a couple of times and had no problems with it. So quiet.
PostPosted: Mon May 29, 2017 4:01 pm
Current aeroad is bb86 https://www.canyon.com/en-sg/road/aeroa ... x-9-0.html
Sent from my Redmi Note 4 using Tapatalk
My Tarmac SL3 http://weightweenies.starbike.com/forum/viewtopic.php?t=136991
PostPosted: Mon May 29, 2017 4:41 pm
Oops, yes you're right, the spindle is 30mm on her Rotor, think I've been using pressfit 4130's or 4630's. Have to go back through emails to check. Sorry OP if that was misleading!
PostPosted: Mon May 29, 2017 5:56 pm
AFAIK, my new Foil is BB86**.
**edited
(I knew it was some sort of press fit bearing and assumed it was BB30 reduced to 24mm for my SRM. I was wrong)
Twitter: @FormerTTchamp https://twitter.com/FormerTTchamp
PostPosted: Mon May 29, 2017 6:45 pm
The Canyon Aeroad and the Scott Foil both have a BB86 bottom bracket.
PostPosted: Mon May 29, 2017 8:26 pm
The only "modern aero" frame I know uses BB30, is Felt AR, just as already said in this thread.
In aero terms, as fast as S5, Madone, Venge.
There are no new unread posts for this topic. Aero bars on non aero race bike
gurk700
16
2834
Sat Mar 18, 2017 6:32 pm
kode54 View the latest post
There are no new unread posts for this topic. BB30 question plus new bike
Dennistwowheels
Sat Oct 29, 2016 12:58 pm
alcatraz View the latest post
There are no new unread posts for this topic. Factor One Aero bike. Anyone?
Noctiluxx
Mon Aug 14, 2017 2:55 pm
Noctiluxx View the latest post
There are no new unread posts for this topic. Fenders for Aero Bike
Wormiez
13
1345
Fri Oct 28, 2016 9:09 pm
baldy View the latest post
There are no new unread posts for this topic. BB30 circlips when fitting BB30-24mm Bottom Bracket
thepainandsuffering
Mon Oct 16, 2017 1:26 pm
hambini View the latest post
Users browsing this forum: bremerradkurier, Delorre, DiegoMendes, jever98, PLuKE, pyrahna, stormur and 39 guests
