It is currently Sun Oct 22, 2017 4:20 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Sat May 27, 2017 10:25 am
Hi guys!
New member to the forum, but a long time lurker :roll:
I'm hoping someone can offer some advice. Me & my brother ordered an 'ex-pro' Canyon Ultimate SLX from the Canyon website. The bike came built up with SR EPS, but I have stripped the frame as my brother will be building up something else with this. I'm building the bike up with SRAM Force instead to use for racing on, however it seems that the bike is missing some cable stops in the frame...the right side is fine, but the left entry is basically a big hole straight through into the frame:
http://imgur.com/a/1IdpW
I'm guessing there is some sort of stopper than can be fitted for the outer cable to slot into. Does anyone have any experience with this, or can offer any advice regarding parts needed to create a fix? I'm contacting Canyon but was hoping to be using the bike pretty soon...
The bike is missing the same from the rear mech cable exit, but I have created a temporary fix for that at the moment.
Thanks in advance!
PostPosted: Sun May 28, 2017 5:57 pm
The Canyon electric and mechanical frames are different, so you might have problems trying to use Force on an EPS-compatible frame.
PostPosted: Mon May 29, 2017 8:55 am
eoj wrote:
Hi guys!
Thanks in advance!
you selling the EPS?
PostPosted: Mon May 29, 2017 10:17 am
I was worried that the frame would be the electronic model, but this is a mechanical frame that has been modified to fit EPS (drilled). It just seems that the one internal port has a plug missing. The other port had a rubber/glue substance plugging it up as it wasn't used for electronic.
Unfortunately the EPS isn't for sale!
PostPosted: Mon May 29, 2017 5:51 pm
Do what I did and just go with etap.
PostPosted: Tue May 30, 2017 3:26 am
Call or message Canyon. They are awesome about sending small parts. I've found the Canyon UK guys to be excellent.
There are no new unread posts for this topic. Canyon Ultimate CF SLX 2015 model
Timujin
Fri May 19, 2017 11:41 pm
totalcompactroad View the latest post
There are no new unread posts for this topic. Stems with internal cable routing
murphyk
Fri Oct 13, 2017 4:14 pm
kode54 View the latest post
There are no new unread posts for this topic. Link cable housing and internal full length runs?
SpecializedColnago
Wed Apr 12, 2017 1:53 pm
reknop View the latest post
There are no new unread posts for this topic. Canyon Ultimate CF Evo
bruno2000
Mon Aug 28, 2017 1:53 pm
bruno2000 View the latest post
There are no new unread posts for this topic. Canyon Ultimate EVO
lovemyway
36
7998
Tue Sep 05, 2017 5:03 pm
inchul View the latest post
Users browsing this forum: cyclenutnz, movemint, Seedster, Sm0421 and 26 guests
