hambini wrote:I have some 80mm Zipp 808's, the alleged improved handling in cross winds is rubbish. They are a nightmare. Anything more than 35km/h and I go to Shimano C60's (50mm). They are not as good as my old Shimano C35's in cross winds but they are at least manageable. The worst time is when trucks go past me.
Tour test 8/2016 steering moment on bars at 12.5° crosswind:
Mavic Ksyrium Pro Exalith SL | 0,0001
Fulcrum Racing Quattro | 0,0025
Mavic Cosmic Pro Carbon SL C | 0,0035
Reynolds 58 Aero | 0,0045
Mavic CXR Ultimate 60 | 0,0060
Zipp 404 Firecrest | 0,0070
Zipp 808 NSW | 0,0125
Your Shimano C60 were also tested, but without concrete numbers - the rating of crosswind stability was a little worse than the Mavic CXR Ultimate 60 though.
The NACA teardrop shape seems the way to go, but as stated, with a slight aero penalty at high yaw angles.
But even with the Reynolds, 80mm stay 80mm.
Maybe the 65mm on front will be the best choice for you:
But only for 23mm tires and good roads. I need 25mm on 21C here.
