It is currently Sun Jan 21, 2018 7:30 pm
 Post subject: bc1.37 bb question
PostPosted: Thu May 25, 2017 7:13 pm
Hi there. I have a Cervelo P2 with a “bc1.37 x 24” bottom bracket.
Is there any way to get a 30mm crankset through it?
Thanks in advance :)
 Post subject: Re: bc1.37 bb question
PostPosted: Thu May 25, 2017 9:01 pm
You mean BSA?
If you get a BSA30 crank and BB, or a BSA 368 crank and BB it should fit. Forget trying to fit a normal BB30 crank in though.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
PostPosted: Thu May 25, 2017 9:22 pm
To expand.
Your BB now is a English threaded one, also called BSA.
A "long" spindle BB30 crank will work with the correct threaded cups. You will then have a setup also known as BB386evo.
FSA, Rotor and others make these cranks but as the poster says a conventional BB30 crank will not fit.
Here is such a setup Image
The difference Image
FSA and others make cups Image
There's sometimes a buggy.
One.
PostPosted: Thu May 25, 2017 11:28 pm
you are better of just using a 24mm or 22mm
PostPosted: Fri May 26, 2017 12:37 am
I have a 2011 Cervelo S3, which is also has a BSA threaded bottom bracket, and I've been using a wheels mfg BSA30 bottom bracket and a Rotor 3D+ crank. I have over 10k miles on this setup and it's been solid, no reason to not use a 30mm spindle crank.
PostPosted: Fri May 26, 2017 12:42 am
And why is that?
I have 2 bikes with bsa bottom bracket and 30mm quarqs both have the bsa30 bottoms brackets from Kogel
Skunkworks Bikes
PostPosted: Fri May 26, 2017 6:00 am
It's never going to be very durable because the bearings are quite small.
Most "innovations" in cycling are solutions for non-existing problems.
PostPosted: Fri May 26, 2017 6:08 am
Online
They sit outside the frame, so why they make them smaller?
PostPosted: Fri May 26, 2017 6:28 am
exactly they are full sized 6806 bearings as found in all pf30, bb30, evo386, osbb, pf30a and BBright :thumbup:
Skunkworks Bikes
PostPosted: Sat Jun 03, 2017 7:18 pm
Thanks for the help guys. Problem resolved :)
There are no new unread posts for this topic. E Tap question.
Juanmoretime
Mon Oct 30, 2017 11:17 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. KMC X10-93 chain question
Valy
Mon Apr 24, 2017 4:50 pm
audiojan View the latest post
There are no new unread posts for this topic. Cip Bond BB question
Boshk
Sun Aug 13, 2017 3:31 pm
Boshk View the latest post
There are no new unread posts for this topic. Shiv TT question?
CrankAddictsRich
Mon Jun 12, 2017 6:18 pm
CrankAddictsRich View the latest post
There are no new unread posts for this topic. Campagnolo EPS question
wilwil
9
761
Sun Jan 21, 2018 4:12 pm
graeme_f_k View the latest post
Users browsing this forum: Attermann, Google [Bot], themidge and 42 guests
