Aluminium corrosion in a carbon frame?
wilwil
by wilwil
The paint is falling off all round the aluminium cable entrances on a carbon Bianchi Infinito, exposing significant corrosion. Is the frame a write off?
topflightpro
by topflightpro
Probably not.
I had a Cannondale System 6. There was a ton of corrosion where the carbon and aluminum tubing met at the BB. I rode it for several years like that, with the corrosion continually worsening. It was still going strong after 8 years, until I got hit by a car.
sungod
by sungod
pictures?
unless the cf has been damaged (al corrosion product takes up more volume) it should be ok
cf/al interface can suffer from galvanic corrosion if moisture gets in, the al loses
you can apply some acf-50 to treat the corrosion and held prevent it worsening, re-apply every year or so, more often if it's ridden in wet weather a lot
wilwil
by wilwil
[img]
wilwil
by wilwil
Hopefully you can see the picture Ive posted. I have a feeling the gear cable ports will do the same judging by the cracking.
I now notice there is probably corrosion round the BB and the paint is bubbling round the rear drop outs.
Calnago
by Calnago
Are you the original owner? If so, I would see what Bianchi might do for you, regardless of whether it's still under warranty or not.
chris8382
by chris8382
I had similar galvanic corrosion on the rear dropout of my Colnago C40. In that case, with the corrosion affecting structural integrity of the frame, I had to have the dropout replaced with a new steel hangar. Not cheap, but the frame was much improved. In your case, this aluminum cable guide/insert is not structural...you can probably treat it as described above and then continue to enjoy the frame for years.
_______________________________
Road: Colnago C50
Cross: Ridley X-Fire
Tri:Trek SC 9.8
