It is currently Tue Jan 16, 2018 10:49 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page 1 2 3 Next
 Post subject: Annoying sound :(
PostPosted: Mon May 22, 2017 8:46 pm
Starting from the end : I exclude EVERY other sound. And still have "clicking" coming from seat tube area.
to avoid misunderstanding : it's NOT coming from BB ( out of saddle is silence ), it's not saddle ( switched 3 ) not saddle clamp ( lubricated ) not seatpost clamp ( changed 3 ) . Left seatpost. To be more precise its length : thing is 400mm long, 260mm seats in seat tube.
Cutting seatpost voids warranty, so I have to be quiet sure before shortening the thing( proprietary ) ...
But , IS IT POSSIBLE AT ALL that "to long" seatpost is "clicking" , or rather knocking inside seat tube ? I happens ONLY in certain situation : in saddle, cadence 90ish, avg power ( not light spin, neither hammering ).
Did it happened to anyone ?
Mark Twain
 Post subject: Re: Annoying sound :(
PostPosted: Mon May 22, 2017 9:00 pm
Do you have a spare seatpost/saddle from another bike you can just swap in place?
Colnago C59
PostPosted: Mon May 22, 2017 9:05 pm
If used, try another friction compound (if carbon post). Eg effeto mariposa carbogrip or motorex carbon assembly paste.
PostPosted: Mon May 22, 2017 9:14 pm
Have you checked/changed the front and rear skewers?
PostPosted: Mon May 22, 2017 9:20 pm
I tried already 3 different carbon assmbly compunds ( Pinarello, Ritchey, Tacx )... and without any compound as well.
temporary no access to same dia post :(
skewers are DT RWS-> no chance for any sound from there
Mark Twain
PostPosted: Mon May 22, 2017 9:24 pm
That's a good idea. My mystery noises in the past have usually come from skewers and saddle/seatpost.
Colnago C59
PostPosted: Mon May 22, 2017 9:26 pm
it's bad idea. if I raise butt just 1mm above saddle noise is gone. it's coming from the line butt-seat tube.
Mark Twain
PostPosted: Mon May 22, 2017 9:31 pm
I've had noise that went away when I got out of the saddle. A very thorough cleaning of both front and rear wheel skewers solved the problem.
PostPosted: Mon May 22, 2017 9:47 pm
skewers new and greased
Mark Twain
PostPosted: Mon May 22, 2017 9:54 pm
Then either try a different seatpost or get out the hacksaw.
Colnago C59
PostPosted: Mon May 22, 2017 9:59 pm
hacksaw voids warranty for 3k€ frame, so it's kind of "last resort" solution. Have to arrange short post... Had while ago long posts seating in, but never such issue ...
Mark Twain
PostPosted: Mon May 22, 2017 10:25 pm
I thought you meant that the hacksaw voids the warranty on the seatpost. How doesn't it void the warranty on the frame? Some kind of integrated setup?
Colnago C59
PostPosted: Mon May 22, 2017 10:38 pm
yep. unortunately.
Mark Twain
PostPosted: Mon May 22, 2017 11:16 pm
Just continue riding. If it's a bearing it will get worse and the location will sooner or later reveal itself. Lesson learned....
/a
PostPosted: Tue May 23, 2017 12:23 am
no idea what you smoked, but I'm jealous...
Mark Twain
Users browsing this forum: Baidu [Spider], Bing [Bot], celestia07, Google Adsense [Bot] and 36 guests
cron
