Enve 3.4 SES and Zero Gravity Brakes
by markcp
I've run Enve 45 tubs with Zero Gravity calipers (06 ti) for a number of years with no issues. However, the front rim looks like its developed an issue which will hopefully be covered under warranty.
Since Enve don't make the 45 rim anymore and are out of stock, they've offered a 3.4 SES as a replacement. My only concern (apart from the weight hike!) is that it won't fit in the Zero Gravity caliper - does anyone run this combination with it working ok?
by Beaver
Now there are 8mm instead of 10mm thick brake pads - so you could get another 4mm of clearance. Enve's 3.4 are 27.5mm at the brake track. If a 24mm rim fits it's no problem.
