THM Clavicula SE installation
by adamdoc12
Just received a new THM clavicula se crank, the crank arm was installed when i received it and i cannot get it off the spindle, i've removed the pinch bolt and adjustment bolt but it's not moving at all, am i missing something or doing something wrong?
by spdntrxi
Should slide off at that point.. lightly tap with rubber mallet maybe
by jimaizumi
spray some degreaser into the contact points and lightly tap the crankarm away from the spindle.
:oops: THE PAST: 2005 Cannondale R700, 2006 Specialized S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
:D THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato
:wink: THE FUTURE: :mrgreen: :mrgreen:
by 4ibanez
It's a bit of a PITA to get off the spindle I've found. Keep at it, you'll get it off the spindle eventually. Give it a jiggle, also you can probably treat it a bit rougher than you think!
by audiophilitis
Rubber mallet is your friend. The cranks are not as fragile as they seem -- they can take some pounding of a rubber mallet. Wrap the mallet with a towel for extra protection against scratches
