Help disassembling Trek Domane 6 Series
Danza
by Danza
So I have a Domane 6.9 that I am stripping down and stripping paint for repaint. I haven't been able to find good info on the Trek website in terms of a shop manual, so hopefully some of you can help:
1) I was able to remove 1/2 of the isospeed hardware, but the other end of the hex screw seems to still be attached. Am I missing something or is there any tips with removing this?
2) The issued bearings seem to be held in place, are these press fit? I expected them to be slip fit.
3) Is there any way to remove the rubber grommet between the seat tube and top tube around the isospeed?
4) Does anyone know the P/N for Trek mechanical groupset hardware kit? This frame was previously Di2 and I cannot locate the cable stops.
Danza
by Danza
Also any idea if this frame is EPS compatible?
MoreRideTime
by MoreRideTime
@Danza It looks like the Trek part number for the the hardware is 431218 - Frame Hdwr. Kit. Drop me a PM and I can dig up the assembly guide for you. That should provide the info you are after about the Isospeed.
