It is currently Sat Oct 21, 2017 1:04 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
PostPosted: Fri May 19, 2017 3:25 am
Time to get an endurance style road bike.
Steel? What Kind?
OR
Carbon? What Kind? (will it crack?)
Calipers?
OR
Disc?
Too many choices. Ride for fitness. A few short trialthlons & few centuries a year. Budget between 3K and 4K....HELP!
PostPosted: Fri May 19, 2017 9:23 am
Columbus HSS Spirit / Discs.
PostPosted: Fri May 19, 2017 12:22 pm
Online
Steel with standard calipers. Chris King Cielo. No need for disc, all that added weight for not a lot of benefit. I go down mountains just fine with calipers.
PostPosted: Fri May 19, 2017 12:31 pm
Carbon Toray........no discs
PostPosted: Fri May 19, 2017 12:53 pm
I recently got a steel bike. It blows my Canyon CF SLX out of the water. It's sooo smooth and just floats over rough Tarmac that I would bounce around on with the Canyon. The Canyon is a great bike but it feels very flimsy compared to the steel bike.
When I put my deposit down on the bike, I was going back and forth between rim and disc brakes. I finally went for rim because I prefer climbing and I take it easy on the descents. I'm a reasonably confident descender who used to race downhill MTB so I've never felt the need for anything more than the rim brakes I've got.
When the bike arrived in March, it rode so much better than I thought it was going to. The Canyon never gets taken out these days, although having said that, I am eyeing up some hill climbs this year so it would be brought back into service due to being about 1.5kg lighter.
PostPosted: Fri May 19, 2017 12:55 pm
Oh I forgot to mention, I ride live and ride in Japan. The Japanese weather is pretty stable so I tend to only ride if the weather forecast is favourable. I rarely get caught out in rain. If I lived/rode in my home country (northern England) , I might be tempted to go with discs.
PostPosted: Fri May 19, 2017 2:28 pm
Yes, have been told that type of steel is lightest and strongest...now, how do I find a frame that is made with it? My current bike is 22 years old, columbus brain tubing. Everything is just wearing out. It weights 24.5 pounds or 11.1 kg. A bit heavy.
Ready for a bit of a more upright ride. No more racing or crits.
PostPosted: Fri May 19, 2017 3:57 pm
I will say that disc brakes are amazing. It would be hard for me to buy a new road bike without them, regardless of that frame's material. I have Shimano hydro disc on 2 cx bikes and my wife ahs them on 2 cx bikes as well. They're simply amazing.
It's also easier to run bigger tires with the disc brakes, without going to long rear caliper brakes.
For material, I'm a fan of Life tubing if you aren't too big a rider. If you can get a builder that has OX platinum in stock still that is also a great option. Reynbolds 853.
It's hard to go wrong with modern steel tubing. I would be more concerned with the builder than a particular tubeset.
Chris King Cielo, Speedvagen, Breadwinner, all great and readily accessible.
PostPosted: Fri May 19, 2017 4:24 pm
I'd take a good look at the Trek Domane, quite frankly. I prefer the simplicity, functionality and lighter weight of a good rim brake. I've never wanted for more, so the benefits I just mentioned outweigh any advantage that discs may enjoy in mud, snow and hard rain, which if you're into riding in those conditions, a lot, then have at it. I do have a dedicated rain bike for the road, and the biggest difference is that it has full fenders (far more important a feature in the rain than whether your bike is disc or rim braked), but I still chose rim brakes for it as well. It's rare that I will start a ride in torrential rain these days, but I'm often on the roads after a rain or may get caught out during a ride, and where I live the roads can often remain wet for long periods. The water and crud you get bombarded with from the road and tire spray is worse than what the clouds drop on you, hence fenders are a must, with good flaps. But if you wanted to run really big tires on your road bike, like larger than 28mm (since the new rim caliper brakes will accommodate most tire sizes up to that), then discs are really your only option. Or a mountain bike, which tires that size are probably best suited for.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Fri May 19, 2017 6:00 pm
Enigma Elite - http://www.enigmabikes.com/bikes/fast-e ... gma-elite/
PostPosted: Mon May 22, 2017 1:03 am
+1 to this. Mind you, I'd put the preference as Discs + any frame you want.
PostPosted: Mon May 22, 2017 4:24 am
S-Works Roubaix only comes in disc, and carbon. There it seems to answer all your questions.
S-Works Venge ViAS(7160g)
S-Works Venge(6220g)
S-Works Shiv(7450g)
PostPosted: Mon May 22, 2017 4:51 am
You mention endurance but also some short triathlons - is the Triathlons participation (for fun) or are you looking for a bike that will be suited to fast racing and be at the pointy end of the field? I wouldn't usually put Endurance and Triathlon in the same space.
Do you want something towards the racy end of the spectrum or more towards the touring? Do you want to be able to run full length fenders or racks?
What sort of climate and weather do you ride in?
Is this going to be your only bike?
PostPosted: Mon May 22, 2017 7:38 am
Reynolds 953 + Discs.
PostPosted: Mon May 22, 2017 11:25 am
Focus Paralane
https://www.focus-bikes.com/int/road/paralane
Merckx EM-525 Endurance geometry (=higher stack shorter reach)
http://www.eddymerckx.com/products/road/male
BMC Roadmachine (02 or 01)
http://www.bmc-switzerland.com/int-en/b ... tegra_di2/
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
There are no new unread posts for this topic. Fuji SL 1.1 Disc or Cannondale Synapse Hi Mod Disc or any other Disc Frame under 2000 dollars
vanmatthew
Fri Nov 18, 2016 9:34 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Do Roval Disc CLX 50's fit Canyon Ultimate CF SLX Disc?
dvearn
Thu Jun 01, 2017 6:32 am
hannawald View the latest post
There are no new unread posts for this topic. CAAD12 Disc Fram + New Campy Disc = Compatible?
NewYorkNick
19
2102
Sat May 13, 2017 8:17 pm
NewYorkNick View the latest post
There are no new unread posts for this topic. Zipp 404 Disc Compatible W/ Venge Vias Disc?
Samklee15
Tue Nov 08, 2016 8:13 pm
Samklee15 View the latest post
There are no new unread posts for this topic. Moots Vamoost RSL (non disc) vs Canyon Ultimate SLX CF DISC ?
rolfo
13
1637
Thu Apr 27, 2017 4:02 pm
rolfo View the latest post
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], huddini, jch3n, jwfinesse, PSJoyce and 27 guests
