It is currently Tue Jan 23, 2018 9:23 am
Post new topic  Reply to topic  [ 51 posts ]  Go to page 1 2 3 4 Next
PostPosted: Thu May 18, 2017 1:53 pm
Not perfect - but it appears as though Magura MT6 Calipers use all the same technology as Campy - which makes sense as they are Making Campy's Calipers.
They use the same fluid as well.
From a review on MT6's - sounds just like a Campy Caliper. I would bet Campy pads fit right in as well.
The forged single-piece aluminum caliper uses a double arch design, just like their forks, and the shape optimizes the caliper’s strength in the direction that encounters the largest load forces, and they also absorb heat, and dissipate it away from the main body. The upper or front fin does the oil transfer between the sides of the caliper, which should provide an additional cooling of the fluid? Their stiffening effect, means that the calipers can be machined further, to remove any unnecessary material for a significant weight saving. The caliper uses top-loading pads, for what they call EPR or easy pad replacement, so the wheel doesn’t need to be removed for changes. The caliper has PM mounts, an adjustable hose fitting, and uses two Duroplastic injection molded composite pistons for less heat transfer to the brake fluid, and the pistons have an embedded magnet for brake pad attachment. The organic pads come in two models, the default 7.1 semi-metallic performance versions for maximum power, or the optional 7.2 endurance version for longevity.
Calipers are about 75 Euros each. - A lot cheaper than a new frame though!
PostPosted: Thu May 18, 2017 1:57 pm
and what's the price for the Campag?
PostPosted: Thu May 18, 2017 2:18 pm
A lot... List is 780 Euro for Potenza levers/Calipers, 980 Euro for H11 Carbon Levers/Calipers - street price should be 25-35% less.
I doubt we will be able to buy just the Levers - we will have to keep the Calipers for later when you upgrade to a Flat Mount Frame.
It's not like I haven't bought parts to rip them apart before to make something new.
Like the time I bough a Complete set of i9 wheels as I wanted the Straight Pull Hubs(they don't sell them separately) to build into some ENVE 3.4 Disc Rims
Or last year when I wanted to run 11-32 SR on my Gravel bike and bought a complete Potenza Long Cage RD just for the longer cages to put on my SR RD (The Potenza stuff was too new to buy individual parts).
This hobby is expensive for early adopters.
I'm still hoping Campy reverses itself and makes PM but at least I have a back up plan.
PostPosted: Thu May 18, 2017 4:52 pm
Are you sure they are making the calipers for Campagnolo?.....they were involved in the design, but manufacture?
PostPosted: Thu May 18, 2017 5:04 pm
i thought I read they were - but I would be stunned if they weren't at least making the internal parts.
PostPosted: Fri May 19, 2017 6:30 am
The Magura MT8 Next model calipers were the ones shown on the Campag prototypes last year by the looks of it, I reckon these can be used, and will be aiming to do so. Would just need a different hose connector at the caliper side, similar to the connector Campag uses in the levers to connect to the reservoir.
PostPosted: Fri May 19, 2017 6:39 am
So theoretically as long as you're using the correct oil (no mixing mineral oil and dot systems) for the system and the piston\pot volume is about right, you could stick any calipers on the end...
Chapter 2 Tere
Scott Spark 720plus
PostPosted: Fri May 19, 2017 7:37 am
Hydraulic discs are a lot more finicky when it comes to piston/pot volumes. Its not like cable caliper rim brakes where a little bit more or less is negligible though. You'll have to be very sure if you want to go down that line.
PostPosted: Fri May 19, 2017 9:48 am
There have been pros running saint calipers on xtr levers in the dh scene a while back. Interesting because an xtr piston should be much lesser volume than a saint caliper...
Chapter 2 Tere
Scott Spark 720plus
PostPosted: Fri May 19, 2017 2:19 pm
It will be lot cheaper trying this than Changing my Frame! If it doesn't work I'll have the Campy calipers I need for a new frame.
Campy disc is going on my Gravel/Adventure bike so I'm actually contemplating putting the 4 Pot MT5/7 Caliper on the Front and MT6/MT8 on the back.
I haven't been overwhelmed by Shimano Disc so this solution 4pot/2 pot could be quite powerful - extra weight looks like 70grams.
PostPosted: Sat May 20, 2017 3:25 am
Not aware of any Post Mount (frame) to Flat Mount (caliper) adapters, though the reverse does exist.
Maybe can search around if anyone has done something of that nature for the market ?
PostPosted: Sat May 20, 2017 11:40 am
If you find anything please let me know - but so far I'm having no luck.
PostPosted: Mon May 22, 2017 1:01 am
I'm running Zee calipers with RS685 Road levers. The theory is that the larger caliper piston volume will lead to spongier lever feel, but it's fine.
Compared to factory installation of RS685 levers and RS785 calipers, my brakes felt the same at the lever.
Braking is great, modulation brilliant, and the bigger pads last longer and take longer to get hot. Suits my Clydesdale frame well :D
PostPosted: Fri May 26, 2017 4:01 pm
Keen to hear what you guys find, got a post mount frame that's been crying its wee eyes out since Campag's flat mount only announcement.
Cinelli Saetta 6.5kg - nice and dry weather
Reilly T325 7.3kg - nice weather but windy
Spa Audax 9.1kg - all weather steel beauty
Pinnacle Dolomite 7.9kg - flat-pedal chainguard thing
M∆SON Definition 8.5kg - off-road ... thing
PostPosted: Sun May 28, 2017 6:05 pm
Interesting thread!
Not to change the subject, but I'm wondering if you all would think that the Mt6 6-bolt storm rotors would work with campy's disc calipers?
There are no new unread posts for this topic. Converting flat mount to post mount
Miller
Wed Mar 01, 2017 11:55 am
Broady View the latest post
There are no new unread posts for this topic. go pro mount seat post
nohands
Sat Jul 15, 2017 5:28 am
mpulsiv View the latest post
There are no new unread posts for this topic. New Wilier has direct mount caliper / disc and swappable dropouts all in the same frameset
jeffy
Wed Jun 28, 2017 7:07 pm
MyM3Coupe View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo compatible Direct Mount Bottom Bracket Brake Suggestions
J.v.S.
Thu Mar 09, 2017 10:01 pm
J.v.S. View the latest post
There are no new unread posts for this topic. Would a Campagnolo 10 Speed 12-30 cassette work on a bike with a med rear mech?!
Greatwhite7
Sun Nov 19, 2017 11:45 pm
Greatwhite7 View the latest post
Users browsing this forum: Baidu [Spider], Conza, Google Adsense [Bot], jlok, MattN, vladi78 and 30 guests
