derailleur for 10spd campag
by vejnemojnen
so, I'd be brief.
I'd build up a bike with 10spd parts, due to the low cost of 10spd cassettes-chains (and availability of 13-26 ratios)
I'd definitely pick new 10spd veloce shifters, due to the lever shape&eps style buttons, but I'm torn what rear derailleur shall I choose. According to official recommendations, these new power shift levers should not be mixed with older 10spd components (eg.: older record-chorus from 2008). Should I just stick to the official recommendations, or can I combine the new levers with old chorus rear derailleur?
thanks in advance for the input. :welcome:
by bikerjulio
I believe it would work in terms of actuation ratios, but the major difference is in the spring tension.
I have a current Veloce 10-spd setup, which works excellently. It is surprisingly good. My advice, and because Veloce stuff is so reasonably priced, is to go with the matching RD.
There is also a 13-29 if you want. And there was an excellent 12-30 in Centaur which you may find around.|s28JFwVLp_dc|pcrid|55959038492|pkw||pmt||prd|468398CA
There's sometimes a buggy.
by bm0p700f
I use miche cassettes as there infinate options. Got a 16-29T on one of my 10 speed campag bikes. Veloce 10 speed works very well.
by vejnemojnen
Thanks. I have 12/25 and 13/26 as well. I live in a am
Flat area, so the finer the better, that is why i mainly choose 13/26.
Moderator Note: Ebay link deleted. Please read the rules.
