It is currently Tue Jan 16, 2018 10:46 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Wed May 10, 2017 10:42 pm
Hi,
I'm having a bit of a nightmare and I think it's to do with the Tune housing (the white plastic stuff). It's seemingly very stiff and slightly too little or too much cable seems to hold the brake over to one side or the other. I made an in-between cut and managed to set the brakes in the perfect position. Unfortunately one side still seems to be getting influenced by the outter. When I pull the lever, one side comes in nicely but the other barely moves in 1mm.
I'm so confused and wearing out my rear brake cable fast! I set the front up with no issues at all!! Please help!!
Supersix Evo Hi-Mod - 4.51kg
PostPosted: Thu May 11, 2017 12:06 am
I don't think I have a straight-up solution, sorry. Thinking it through, it's the cable pushing against the stop at the brake and that brake arm does not want to move in onto the rim? So the length becomes super critical?
I'm about to (in good time) set up for the first time using Tune housing on TriRig front and EE at bb; don't think though that I'll run into similar problem. If I do, I'll just have that last short length in Campag cable. Yes I agree it's stiff and I was more thinking how it'll go at the front end (handle bars).
Less is more.
PostPosted: Thu May 11, 2017 7:24 am
I thought if I cut the outter short then it may not push the adjuster. I think I still need to trim more off, but I'm off on holiday tomorrow so it'll have to wait. I thought this Tune housing was gonna be a breeze compared to i-links but I'm wrecking my ti brake cable atm. Any suggestions welcome - there are defintely a few people here who have used this or a similar setup.
PostPosted: Thu May 11, 2017 5:18 pm
Been thinking about this far too much. It could be the square at the rear that the spring sits on. Mine has always been very thin there and the spring has come unseated before. I could try gluing the spring in place - think I've got some glue somewhere courtesy of HQ Fibre.
PostPosted: Thu May 11, 2017 8:36 pm
Use normal cable till you get the length right, no?
Less is more.
PostPosted: Fri May 12, 2017 5:02 am
Wasn't anticipating any problems when I set out, but I managed to fix it now anyway. I don't know exactly what did it, but it seems outter length wasn't the problem. I took it apart, cleaned, re-assembled, played with cable adjustment and am using one of the lengths of outter I cut before. All's well that ends well.
PostPosted: Fri May 12, 2017 5:23 am
Sweeeet. Do let us know whether you like this bit of wwism.
Less is more.
There are no new unread posts for this topic. Setting up the Shimano Di2 EW-RS910 Bar End Junction A Charging Point 2 Port
melchionda
14
5063
Thu Dec 21, 2017 9:22 pm
Roeieber View the latest post
There are no new unread posts for this topic. Sram red 22 and segmented housing
NiFTY
Tue Sep 12, 2017 3:54 am
dereksmalls View the latest post
There are no new unread posts for this topic. Jagwire XEX-SL and KEB-SL derailleur and Brake housing
tommasini
Mon Jan 01, 2018 4:44 am
Mep View the latest post
There are no new unread posts for this topic. Fluo brake cable housing?
jever98
Wed Mar 15, 2017 7:11 pm
Kurets View the latest post
There are no new unread posts for this topic. Compressionless brake housing for internal routing
bikewithnoname
Sun Apr 16, 2017 7:43 am
bikewithnoname View the latest post
Users browsing this forum: Bing [Bot], crn, micky and 38 guests
cron
