Look pedal removal - allen key vs pedal wrench?
by alcatraz
Pedals: Right is right and left is wrong!
by sawyer
ManekiNico wrote:
dj97223 wrote:. . . ant that you are turning the wrench/key in the correct direction.
I’ve been working on my own bikes for 30 years and I still have to look this up … Every. Damn. Time.
Simple way to remember ... pedals tighten in the same way the cranks rotate to apply power, and obviously loosen in the opposite direction
by Fiery
Yup, to tighten just set the wrench/key as an extension of the crank arm and push as if you wanted to pedal the bike.
by dj97223
While we are passing on advice ... I find there is no need to torque the pedal with much force when installing it. I snug it just a bit and have never had one come loose.
by Rick
Once you are confident of direction, if they are sticking (as the often are) a tap of the wrench end with a rubber mallet can break them free without endangering knuckles.
(Don't ask how I know this.)
Then, for the future, what dj97223 said is correct: they don't really need to be super tight; just snug until "solid".
