It is currently Sat Oct 21, 2017 2:51 am
PostPosted: Tue May 09, 2017 10:35 am
Looking for a photo (can't find anything!) of the bottom of a CX Zero Evo.
Got a new frameset, didn't come with a cable guide.
Do these have custom cable bb guides or just a standard one?
Found this - off a cx zero disc. Same as on the rimbrake?
PostPosted: Tue May 09, 2017 3:42 pm
Here you go! Not the best angle, but I confirm it’s the same custom BB cable guide on my rim brake frame. Sorry yours didn’t include the guide.
PS - That “Made in Taiwan” sticker was the first thing to go. Must have saved 0.01 g! :D
Mom: He was very sickly until he started riding around on that bicycle.
Dad: Yeah... well... now his body’s fine, but his mind is gone.
PostPosted: Tue May 09, 2017 11:27 pm
Thanks
I think I'm missing the entire bag of frame parts -
Missing:
-cable guide
-Rubber grommets for the electronic holes included? and that hole you can see forward of the BB in your picture?
-Is there a grommet that goes into the end of the chainstay where the RD exits?
-does it include a steerer expander?
PostPosted: Wed May 10, 2017 2:08 am
That made in Taiwan sticker is a good thing, not a bad thing!
PostPosted: Wed May 10, 2017 4:10 am
Nah.
It's a constant reminder that you can't afford a C60 ;)
frf (aus distro) is sending me a cable guide so all good.
PostPosted: Wed May 10, 2017 5:34 am
silvalis wrote:
Nah. It's a constant reminder that you can't afford a C60 ;)
LOL, exactly!!! Prosecco taste, birra budget, amirite?
As best I can remember, you should have received the following:
- headset (bearings, compression ring, cover, top cap + bolt)
- fork expander
- seatpost clamp + bolt
- inline cable barrel adjusters (2)
- rubber blanking grommet (1)
- plastic chainstay grommet
- bottle cage bolts (4)
- recessed brake nut (front fork)
- derailleur hanger
- packet of carbon assembly paste
- two weird tubular rubber grommets (?) whose purpose I still haven't figured out
That's what I got anyway.
PostPosted: Wed May 10, 2017 6:05 am
Thanks for the list. I think the frame must be an ex display - the tubing had been pulled. Looks like I'm missing more than I expected
- recessed brake nut - missing this. Will a standard nut work or is this specific for the fork?
- blanking grommet - is this for the electronic FD hole or the charge port underneath?
- chainstay grommet - frf sending me this as well.
- and more stuff missing...
PostPosted: Wed May 10, 2017 5:19 pm
Any recessed brake nut should do the trick. The original was 28 mm long end-to-end (25 mm end-to-flange). I replaced mine with a titanium nut from Toronto Cycles.
Electronic FD hole or charge port? Pick one. Maybe I was supposed to get two grommets? In any case I ended up using generic rubber grommets from an auto parts store to seal both holes. Found a size I was juuuust able to squeeze in.
Good thing the distributor is sending you the cable stop for the chain stay. That one’s kinda critical…
Good luck with your build. Let me know how it turns out. Mine is currently just a hair over 7 kg (size 50S) with room for improvement.
PostPosted: Wed May 10, 2017 5:22 pm
Often the fork brake nuts are specific to the fork. Just make sure you can get at least 6 threads engaged without the brakenut bottoming out (too long). Less than 6 threads engaged (Campy's recommendation) and then you start to compromise holding strength etc.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Tue May 16, 2017 7:14 am
Distributor fail. Sent me a generic cable guide that doesn't come close to fitting. Can't really cut it up to suit either.
And the rd cable grommet sent is the wrong size as well
Back to sq one. Might try to get a shop to source it this time.
There are no new unread posts for this topic. BB cable guide bolt problem
wilwil
Sat May 06, 2017 9:39 am
jekyll man View the latest post
There are no new unread posts for this topic. Tarmac SL bottom bracket cable guide mechanical setup
ak47
Mon Mar 27, 2017 12:11 pm
cyclespeed View the latest post
There are no new unread posts for this topic. Colnago C60 Sizing Guide for short leg
bryrene
33
2648
Sat Aug 19, 2017 9:06 pm
cdkoo View the latest post
There are no new unread posts for this topic. Caad12 rear brake guide missing?
Nejmann
Sun Sep 10, 2017 2:08 am
TarugoKing View the latest post
There are no new unread posts for this topic. Colnago Super vs Colnago Master X-light
Kupepe
Sun Jan 08, 2017 6:57 pm
Kupepe View the latest post
Users browsing this forum: cybernck, jerbax18, joejack951, PinaF8, Yahoo [Bot] and 26 guests
