It is currently Thu Oct 19, 2017 1:39 am
Post new topic  Reply to topic  [ 35 posts ]  Go to page 1 2 3 Next
Which cassette?
Sram Red 31%  31%  [ 16 ]
Shimano Dura-ace 20%  20%  [ 10 ]
Shimano Ultegra 43%  43%  [ 22 ]
Other 6%  6%  [ 3 ]
Total votes: 51
 Post subject: Cassette Durability
PostPosted: Sun May 07, 2017 8:17 am
Hi all.
I have an Ultegra 6800 drivetrain on my Scott Addict.
I have been told by the LBS that the cassette will need replacing soon and I have only ridden 5400km on the bike.
When the cassette wears out I would like one that is more durable.
I have heard mixed things about the sram red single piece (mostly) cassette lasting ages.
Does anyone have experience with running it on an Ultegra drivetrain?
If mixing brands isn't ideal would the Shimano Dura-Ace cassette last much longer than the Ultegra to justify the price jump?
Thanks in advance, any help is appreciated.
 Post subject: Re: Cassette Durability
PostPosted: Sun May 07, 2017 8:32 am
No. The dura ace cassette won't outlast the ultegra. You pay more for dura ace because it weighs less (wank wank).
Sent from my SM-G935F using Tapatalk
PostPosted: Sun May 07, 2017 9:19 am
Your LBS is thinking at his benefits, because de durability of a Ultegra cassette is about 15.000km and more IF you change the chain every 3000km or at least before it's used at 0,75 checked by a chainchecker.!
Once comes a time that you'll have a tailwind :D
Pinarello F10 - Ultegra 6800 - Carbonspeed C38 - Tubeless
PostPosted: Sun May 07, 2017 10:27 am
L
Aso sein
Gesendet von meinem A0001 mit Tapatalk
PostPosted: Sun May 07, 2017 10:45 am
Thanks for the help. Current chain has 3100km on it. Should I change it or wait until my chain checked reaches 0.5
PostPosted: Sun May 07, 2017 11:03 am
If you change the chain before real wear, an Ultegra cassette should last at least 4 chains. My Campa Record cassette is on it's 4the or even 5th chain witthout any problem (around 15.000km per Strava) The higher grade you go on cassette's, generally, the faster the wear.
Canyon Ultimate CF SLX 2013
Scott Addict Orica Greenedge
Canyon Endurace CF SLX
PostPosted: Sun May 07, 2017 11:17 am
Thanks for the insight. I must have just found some incorrect information on the red monoblock wearing much slower.
PostPosted: Sun May 07, 2017 11:33 am
Red is full steel, so wear should not be that bad. Big benefit of Red or Edco monoblock : it won't eat into your cassette body. Nor do Campa cassette's. Wy not look into those? They are a little pricy, but not worse than a red cassette and last very well.
PostPosted: Sun May 07, 2017 11:52 am
Delorre wrote:
Red is full steel, so wear should not be that bad. Big benefit of Red or Edco monoblock : it won't eat into your cassette body. Nor do Campa cassette's. Why not look into those? They are a little pricy, but not worse than a red cassette and last very well.
much as I use and like Campy, I don't think OP wants or needs to change his freehub.
OP, how did the LBS determine that the cassette would need changing? By looking at it? That's a poor method.
Do what others here suggest and change the chain before too much wear is apparent.
Ultegra cassettes are just fine.
If you ride a lot in wet weather, drivetrain wear will be greatly increased.
There's sometimes a buggy.
One.
PostPosted: Sun May 07, 2017 11:57 am
No thanks happy with my current freehub. He just looked at it, didn't say it needed changing immediately but warned me that it would be one of the things next up. Should I change the chain now or wait until the chain checker says 0.5?
PostPosted: Sun May 07, 2017 12:03 pm
JScycle: wait until it says 0.5. However if you are on your first chain and it doesn't even say 0.5 yet, then i have serious doubts that the cassette needs to be replaced soon.
PostPosted: Sun May 07, 2017 12:29 pm
I think it is currently my third as one got bent therefore needing a replacement sooner than normal
PostPosted: Sun May 07, 2017 6:43 pm
Many pro-teams use Ultegra cassettes rather than Dura Ace, mainly down to a combination of cost and the well known issues with the Dura Ace cassette nylon/composite parts.
The other issue with cassettes is that wear is never uniform across the full range. Everyone has their own personal cadence and favourite front/rear gear combinations to suit particular terrain. So you'll be changing your cassette when the most used cog wears out.
PostPosted: Sun May 07, 2017 7:23 pm
Durability of a cassette is not standing on it's own . . .
What degrades a cassette?
Main cause:
A stretched chain
Sub cause:
A filthy drivetrain is sanding the cassette
Cross-chaining gives sidefriction
Wet weather
Shortness of lube
High power
The durability of a cassette is depending on all of the above.
Proven method to keep drivetrain functioning as best and as long as possible and saving money:
With a new cassette buy 3 chains.
Use first chain for about 1000 km then take off and lay in closet.
Use second chain for about 1000 km then take off and lay in closet.
Use third chain all the way up (till a chainchecker tells its done)
Then use the first chain till done.
Then use second chain till done.
In this way the sprockets degrade gradually and most slowly.
New chains don’t fit right in a used cassette but the prestretched ones will.
Changing chains with even shorter intervals and never wear till done result in even a longer durability of your cassette.
But all needs to be in balance. An Ultegra cassette is not real expensive so when you buy many many chains on only one cassette its not a right calculation model that is in balance. But with more expensive cassettes (Dura Ace Record) it maybe is worth to use more chains and never wear them completely.
BTW
Ultegra chains are not the best product. They wear fast.
Buy chains in bulk to limit shipping costs.
Buy missing links in bulk (like KMC missing links on ebay)
PostPosted: Sun May 07, 2017 8:48 pm
My record chain and cassette are worn now after 3 years and about 24k kilometers. No chain changes are anything
There are no new unread posts for this topic. Campagnolo 11/32 cassette
markyboy
7
1051
Tue May 30, 2017 11:48 am
garjo View the latest post
There are no new unread posts for this topic. Anyone got a 36t cassette and can help me with the diameter of that cog?
alcatraz
Thu Jul 06, 2017 11:22 am
Kurets View the latest post
There are no new unread posts for this topic. How many miles on your cassette?
Willem
30
2547
Tue Jul 18, 2017 12:10 pm
PrimO View the latest post
There are no new unread posts for this topic. Help me choose a cassette
zalle
10
1609
Thu Dec 01, 2016 7:25 am
mpulsiv View the latest post
There are no new unread posts for this topic. 11-29 vs 12-29 SuperRecord Cassette
3Pio
35
2872
Fri Dec 23, 2016 2:24 pm
3Pio View the latest post
Users browsing this forum: 2phat2slow, Baidu [Spider], jlok, joepac, LouisN, perwjensen, springs, Yahoo [Bot] and 35 guests
